> Leak Around Valves? or Valve Cover?
kbrunk1
post Nov 7 2012, 10:45 PM
Brunk
I have a sizeable drip going. (driver side)
I put the new slghtly oversized cork valve gaskets under the covers.
I used a tiny bit of ?forgot name? gasket seal to hold while putting in place (four corners).
One side is fine. no leak (passenger side)
I think the driver side is fine also concering the cork seal and the cover.
It seems the leak is coming from the round pipes going into the valve adjustment area where you set the valves (from back side where the cover goes).
Has anyone else had this issue?
Is this a drop engine repair? (hope not)
I have a spare set of cork seals and could try another round, but do not think this is the problem.
Oil hits the exhaust then runs downhill and drips at two spots.... real bummer...
Smoke and nasty smell....
nathansnathan
post Nov 8 2012, 11:04 AM
When I say sizeable leak, I mean like dripping out while you're looking at it, when it's running. Valve covers usually are the leaks that do that. It sounds like it could be the pushrod tubes in your case. A valve cover leaking, though, you can see it. Any time I mess with those, I take a look under the car just as soon as I start it after - you can loose a lot of oil there quick and make a good mess, too.
kbrunk1   Leak Around Valves? or Valve Cover?   Nov 7 2012, 10:45 PM
nathansnathan   If the drip is sizeable as you say, then it is pro...   Nov 8 2012, 07:40 AM
kbrunk1   I checked the cork seal and it was not pushed up. ...   Nov 8 2012, 10:27 AM
Rand   I checked the cork seal and it was not pushed up....   Nov 8 2012, 11:51 AM
nathansnathan   When I say sizeable leak, I mean like dripping out...   Nov 8 2012, 11:04 AM
luskesq   Assuming that your valve cover gaskets are correct...   Nov 8 2012, 11:21 AM
SLITS   I has installed new pushrod seals prior to a RRC e...   Nov 8 2012, 02:11 PM
kbrunk1   the link on pellican was for the oil cooler not pu...   Nov 8 2012, 05:47 PM
ConeDodger   the link on pellican was for the oil cooler not p...   Nov 8 2012, 06:05 PM
dpires914   the link on pellican was for the oil cooler not p...   Nov 8 2012, 08:39 PM
michael7810   I had a leaky valve cover due to it being bent on ...   Nov 8 2012, 07:19 PM
kbrunk1   Step 1- jack up car onto jackstands, drain oil etc...   Nov 8 2012, 10:20 PM
ConeDodger   Step 1- jack up car onto jackstands, drain oil et...   Nov 8 2012, 10:32 PM
kbrunk1   /I suppose you were talking about the push rods. O...   Nov 8 2012, 11:06 PM
ConeDodger   /I suppose you were talking about the push rods. ...   Nov 8 2012, 11:26 PM
kbrunk1   So rockers do not need to come off?   Nov 9 2012, 12:24 AM
ConeDodger   Take it to a mechanic. :blink:   Nov 9 2012, 01:20 AM
Dave_Darling   The rocker arms come off. To do that, you remove ...   Nov 9 2012, 12:22 PM
SLITS   As you slide the rocker assemblies off their mount...   Nov 9 2012, 04:32 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:59 AM
