1973 2.0 Original Survivor, New brake lines |
914Eric |
Nov 7 2012, 04:07 PM
Member Group: Members Posts: 316 Joined: 7-November 12 From: Northern Idaho Member No.: 15,125 Region Association: Pacific Northwest |
Well I'm a newbie, but looking forward to help, comments, and thoughts as I bring my 73 x19 2.0 back to life. It is Phoenix Red, and I am the original owner, well my dad was, but it was always his and my car. I drove the car to my senior prom in 1974.
Dad passed a few years ago, and I finally freed up the time to get started refurbishing it this winter. This is an original California car has been in storage since 1993. I got it out of storage last month after making room in my shop, and am beginning to take it apart. I will post pictures as I go and keep a running blog going so all of you guys (and gals) can keep me from messing anything up. I want to do it right. Thread Index Pages 1-2 Intro photos; 3 Rear tunnel access; 4 seat belts, underbody; 5 fuel tank removal; 6 shocks, sway bars, brakes; 7 engine; 8 engine, ECU; 9 hell hole; 10-11 exhaust; 12-13 originality; 14 wheel align; 15 heater hoses; 16 heat exchangers; engine out; 17 vacuum elbow, fuel pump; 18 wiring; thermostat; 19 cooling flaps, pedal board; 20 pedal cluster; 21 cooling fan; 22 main seals, injector manifolds, rotor; 23 thermostat |
bigkensteele |
Nov 8 2012, 07:45 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Eric,
If I were you, I wouldn't restore your car. It will be a lot cheaper to go through and clean everything up and preserve it. It is already in very good condition, so it should also be worth more preserved than restored, I would think. Why doesn't it have blue plates? Beautiful car and story! |
914Eric |
Nov 8 2012, 08:38 PM
Eric, If I were you, I wouldn't restore your car. It will be a lot cheaper to go through and clean everything up and preserve it. It is already in very good condition, so it should also be worth more preserved than restored, I would think. Why doesn't it have blue plates? Beautiful car and story! Ken, Thanks. I probably use the words restore and preserve interchangeably when I shouldn't. My original thought after reading many stories over the last year in preparation for this was that I would have some degree of terrible rust that needed taken care of, and the only way to do it right was go to rotisserie. Since getting the car out of storage, and having a couple weeks to look it over, fortunately that just isn't the case. So far I only have a couple real small areas of surface rust with the exception of the battery tray which has a little bit of rust. Don't have the engine out yet, but hopefully the engine compartment will look as good. I agree with you that a car with 100% original paint and everything else is probably worth more than even a perfectly restored one. Even with the few paint chips that it has. The car was running when it was stored, but at a minimun I'll need to pull the gas tank, replace all fuel lines, all vacuem lines, and I'm not sure what else, but then I can check compression and see if she still has more miles left in her. She only has 80K, so I hope so, but after 20 years...who knows. "Why doesn't it have blue plates?" You really know how to hurt a guy. I worked for McDonnell Douglas in St. Louis for 3 years building F15s from 1987-1990. That is when the plates got switched to Missouri, and then back to California. My Missouri plate was "1973 914S" which I still have, but not the original blue and yellow Cali plate. I wasn't very smart back then. (IMG:style_emoticons/default/screwy.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 12:19 PM |
