Windage Tray Failure--Plot Thickens...Crank! |
wndsrfr |
Nov 11 2012, 07:59 AM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Got in about 20 minutes at Roebling then heard serious knocking from the engine...limped into paddock & shut it down. Towed it home (950 miles round trip for 20 minutes on track (IMG:style_emoticons/default/barf.gif) ) and dopped the engine. Couldn't turn the crank by hand on the fan. So, split the cases. Here's what greeted me as I opened it up--one ear of the windage tray had failed and slid over and was caught under the cam. Check the pics--you can see where the cam was striking the sheet metal piece....nice and shiny there.
It's a "CB" bus case.....anyone seen this before? Anyone with a replacement tray?? Now the plot thickens...see the pics of the crank....think it'll buff out? No wonder it lost power.... (IMG:style_emoticons/default/headbang.gif) Attached image(s) |
Valy |
Nov 11 2012, 04:31 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Look at the journal of the rod next to the crank. That crack goes to the oiling channel. What size is it? Looks 80mm to me, correct?
This failure is typical for poorly welded and enlarged cranks. The oiling channel is too close to the wall and weakens the crank. For your next crank, make sure the oil channels were correctly relocated. |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:36 AM |
