1973 2.0 Original Survivor, New brake lines |
914Eric |
Nov 7 2012, 04:07 PM
Member Group: Members Posts: 316 Joined: 7-November 12 From: Northern Idaho Member No.: 15,125 Region Association: Pacific Northwest |
Well I'm a newbie, but looking forward to help, comments, and thoughts as I bring my 73 x19 2.0 back to life. It is Phoenix Red, and I am the original owner, well my dad was, but it was always his and my car. I drove the car to my senior prom in 1974.
Dad passed a few years ago, and I finally freed up the time to get started refurbishing it this winter. This is an original California car has been in storage since 1993. I got it out of storage last month after making room in my shop, and am beginning to take it apart. I will post pictures as I go and keep a running blog going so all of you guys (and gals) can keep me from messing anything up. I want to do it right. Thread Index Pages 1-2 Intro photos; 3 Rear tunnel access; 4 seat belts, underbody; 5 fuel tank removal; 6 shocks, sway bars, brakes; 7 engine; 8 engine, ECU; 9 hell hole; 10-11 exhaust; 12-13 originality; 14 wheel align; 15 heater hoses; 16 heat exchangers; engine out; 17 vacuum elbow, fuel pump; 18 wiring; thermostat; 19 cooling flaps, pedal board; 20 pedal cluster; 21 cooling fan; 22 main seals, injector manifolds, rotor; 23 thermostat |
SirAndy |
Nov 21 2012, 01:24 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Oh, and the rubber cooling flap on that side is mounted upside-down. The edge needs to point downward for it to work properly.
(IMG:style_emoticons/default/popcorn[1].gif) |
914Eric |
Nov 21 2012, 06:46 PM
Oh, and the rubber cooling flap on that side is mounted upside-down. The edge needs to point downward for it to work properly. (IMG:style_emoticons/default/popcorn[1].gif) You have a VERY good eye Andy. I was wondering about the flaps. One is mounted flush with the underbody and curved down...Which pushes air away from the engine. The other has two inch bolts exposed and hanging down from the underbody with the flap mounted between the bolt head and another nut. This flap is curved up so that the air comes in the two inch gap and is then directed up into the engine. This actually looks like it would work better, but I was pretty sure that it was the one that wasn't the original design. How does the one that pushes air away from the engine actually cool it? Some kind of low pressure drawing it away? |
bigkensteele |
Nov 21 2012, 07:40 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I was wondering about the flaps. One is mounted flush with the underbody and curved down...Which pushes air away from the engine. The other has two inch bolts exposed and hanging down from the underbody with the flap mounted between the bolt head and another nut. This flap is curved up so that the air comes in the two inch gap and is then directed up into the engine. This actually looks like it would work better, but I was pretty sure that it was the one that wasn't the original design. How does the one that pushes air away from the engine actually cool it? Some kind of low pressure drawing it away? Eric, you are correct - the flaps are designed to create a low-pressure area in the underside of the engine bay. The engine is cooled by pulling air in from the top, pushing it through the tin and out the bottom. I don't think the flaps were on the early cars, but I can't tell you exactly when they were introduced. Looks like someone did a fairly clever modification to yours in the hopes of keeping the fuel pump and lines cool to prevent vapor locks. The fuel pump was moved up front under the gas tank on '75/'76 cars for the same reason. Moving the pump up front is a common and relatively easy modification to earlier cars. It is pretty clear from the extensive tweaks back there that your dad had a problem with vapor locks. I would think about moving the pump up front. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:45 AM |
