| 914GTSTI |
Nov 22 2012, 09:51 AM
Member ![]() ![]() Group: Members Posts: 275 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Who has stripped their chassie and had it blasted? The good and the bad. And what did you do to the metal after it was striped? My car will be on a rotisserie for the stripping.
Thanks! |
| scotty b |
Nov 22 2012, 07:21 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Dipping = I have no personal experience so I wont comment
Soda = does a good job on paint but does nothing to the rust, bondo, lead etc. Leaves a residue that must be dealt with properly. This has become less of an issue in the last few years. The guy that comes to you ( how I had it done ) Isn't cheap, but neither is his setup. We had a Healy done, exterior only, and he charged us 1800.00 "sand" = It does a great job when the user knows what the hell he is doing. If he doesnt he can severly damage the car.Makes a big mess,it does leave ALOT of grit that will be coming out for years, and for me the finish is a bit rougher then I like, but it gets it all off. Would take me the better part of a day to do a small car, goes through a lot of sand dry ice = I have no idea dustless blasting = this is the system I now have after getting tired of the results with " sand " this setup uses a slurry of water and crushed glass ( recycled bottles ). There is no dust created so it takes minimal room. WILL NOT damage the metal. I have held this thing wide open 2" off of a decklid and couldn't warp it. The water washes MOST of the media off as you are blasting. It uses a chemical called HOLD TITE that is well known in the marine industry to prevent flash rust for up to 72 hours. Works quicker than my old pressure pot using sand, does a great job on paint, rust, bondo slows it down a little but it still does a good job on it. The setup is expensive,it requires a seperate tow behind compressor, if it sits more than 72 hours without being primed it definitely will need some touch up as the flash rust comes on quickly. The slurry does get packed into corners and crevices and doesn't rinse out all that easily. Goes through a fair amount of media sanding = takes forever, makes a HUGE mess,2nd cheapest of all options if you do it yourself torch and scraper = quiet, cheap, clean. Takes a long time, doesn't get into tight spots very well. Easy to warp the metal if you're not careful chemical strip = caustic, messy, not cheap when you add up all the cans you will go through, PITA to neutralize and clean up after, doesnt get the tight spots well They all have their ups and downs. IMHO...Go for what you can afford, just make sure the stripper knows what they are doing |
| MDG |
Nov 22 2012, 07:30 PM
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
IMHO...Go for what you can afford, just make sure the stripper knows what they are doing Ah jeez . . . he's talking aboot his car, Scotty . . . (IMG:style_emoticons/default/rolleyes.gif) |
| 914GTSTI |
Nov 22 2012, 09:09 PM
IMHO...Go for what you can afford, just make sure the stripper knows what they are doing Ah jeez . . . he's talking aboot his car, Scotty . . . (IMG:style_emoticons/default/rolleyes.gif) Thats funny! Thanks to all! I think I am going to go with Soda. Thinking about doing my self. Think I will rent a BIG compressor and have at it? Have the space at my shop,but we will see. So,now its blasted,I was thinking that a weldable primer mite be best? Ideas? |
| scotty b |
Nov 22 2012, 09:15 PM
IMHO...Go for what you can afford, just make sure the stripper knows what they are doing Ah jeez . . . he's talking aboot his car, Scotty . . . (IMG:style_emoticons/default/rolleyes.gif) Thats funny! Thanks to all! I think I am going to go with Soda. Thinking about doing my self. Think I will rent a BIG compressor and have at it? Have the space at my shop,but we will see. So,now its blasted,I was thinking that a weldable primer mite be best? Ideas? Spies Hecker and PPG both make a weld through etching primer. I don't use anything else. I've tried Bloxide too. It works, but makes a lot of spatter. |
914GTSTI To blast or not to blast? Nov 22 2012, 09:51 AM
GeorgeRud Seems that blasting would be the quickest and easi... Nov 22 2012, 11:53 AM
gopack I had mine soda blasted, did a good job of taking ... Nov 22 2012, 11:58 AM
Gint My /6 tub was dipped. The tub was painted and it... Nov 22 2012, 12:01 PM
Eric_Shea
My /6 tub was dipped. The tub was painted and it... Nov 22 2012, 04:11 PM
biosurfer1 5 years? you need to get working on that!... Nov 22 2012, 12:38 PM
cary I'd say it depends on your budget.
Dipping is... Nov 22 2012, 01:07 PM
wingnut86 Many of the blasters down South provide an option ... Nov 22 2012, 01:28 PM
turk22 The dude in Italy had his car put in a kiln/oven a... Nov 22 2012, 03:11 PM
Who has stripped their chassie and had it blasted... Nov 22 2012, 04:04 PM
Gint That's why I paid the big money having it fini... Nov 22 2012, 04:13 PM
BarberDave :trophy:
Has anybody had experence with Dry... Nov 22 2012, 04:50 PM
pcar916 Just had mine fine-grit glass-beaded ($800). ... Nov 22 2012, 06:49 PM
buck toenges
Dipping = I have no personal experience so I wont... Nov 18 2014, 07:05 PM
Cairo94507 I am pretty sure Scotty B will stripping my Six in... Nov 23 2012, 09:06 AM
cary Another new method is wet sand blasting. Its done ... Nov 23 2012, 10:22 AM
Eric_Shea I saw that at SEMA. You must have a rust agent to... Nov 23 2012, 01:44 PM
914GTSTI OK,so I went to HF and R2 came home with me! T... Nov 24 2012, 04:40 PM
cary Looks nice. Good work .................... Nov 24 2012, 05:36 PM
rdauenhauer My experience: 1) had the LE blasted with Sand ... Nov 24 2012, 08:01 PM
914GTSTI
My experience: 1) had the LE blasted with Sand ... Nov 24 2012, 08:14 PM
boxsterfan If you have all the bolts out of the car and it is... Nov 18 2014, 10:09 PM
OllieG
If you have all the bolts out of the car and it i... Nov 19 2014, 02:09 AM
cary I think this is the system that Scotty has.
http:/... Nov 19 2014, 08:57 PM
http:... Nov 19 2014, 09:01 PM
cary I know. That's another $3-$4k. So no... Nov 19 2014, 09:37 PM
scotty b Yes you need a large diesel 185 CFM unit to run th... Nov 20 2014, 07:17 AM![]() ![]() |
Lo-Fi Version | Time is now: 21st September 2026 - 11:01 AM |
