To blast or not to blast?, Striping chassis for repair. |
914GTSTI |
Nov 22 2012, 09:51 AM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Who has stripped their chassie and had it blasted? The good and the bad. And what did you do to the metal after it was striped? My car will be on a rotisserie for the stripping.
Thanks! |
914werke |
Nov 24 2012, 08:01 PM
"I got blisters on me fingers" Group: Members Posts: 10,124 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
My experience: 1) had the LE blasted with Sand & plastic. Mostly sand since there was considerable rust from the remains of fire & the water necessary to put it out. A lot of vacuuming to extricate the grit from all the small orifices but not too bad.
2) had my proj. car soda blasted. My 1st experience ..the good - remarkable fast stripping leaves a residue that unless expressly washed off & neutralized protects the bare metal . Its been a yr since sitting in my garage and barely a trace of flash rust. The bad - Too smooth finish. leaves no tooth to the metal so you must DA or scotch pad entire car before prime. Also as has been mentioned must address areas that have been bondoed rusted or have sealer which it doesnt remove. |
914GTSTI |
Nov 24 2012, 08:14 PM
My experience: 1) had the LE blasted with Sand & plastic. Mostly sand since there was considerable rust from the remains of fire & the water necessary to put it out. A lot of vacuuming to extricate the grit from all the small orifices but not to bad. 2) had my proj. car soda blasted. My 1st experience ..the good - remarkable fast stripping leaves a residue that unless expressly washed off & neutralized protects the bare metal . Its been a yr since sitting in my garage and barely a trace of flash rust. The bad - Too smooth finish. leaves no tooth to the metal so you must DA or scotch pad entire car before prime. Also as has been mentioned must address areas that have been bondoed rusted or have sealer which it doesnt remove. Have you used etching primer? |
Lo-Fi Version | Time is now: 6th June 2024 - 10:57 AM |
