| TC 914-8 |
Dec 1 2012, 01:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 848 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest
The other day I noticed my Speedometer needle bouncing 15-20 MPH swings while at crusing speed. I knew my speedo cable housing was burnt from resting on the header long time ago. I ordered a new cable, a simple job to replace if you don't have a center console, or a 500mil battery relocate cable running in the tunnel along with the speedo cable. So after 2-3 hrs to do a 1/2 hr job I think I'm done. Go for a test drive, and nothing (IMG:style_emoticons/default/confused24.gif) The needle dosn't even move while driving. I pulled the speedo out and verified the cable turns when driving. Hooked up my drill motor to drive the speedo manually and the needle barely makes it to 30 mph at full speed on the drill motor. Put it back in go for a drive and at 30-40 MPH on the GPS the speedo is only 20mph. The needle hangs there when stopped, and now my odometer dosn't turn or clock miles.
Obviously something broke or is worn, has anyone done this repair? is it serviceable? Or am I better off sending it out? Palo Alto spedometer or North Hollywood Speedo are the only ones I know about. Any PNW folks know of a speedo shop in Seattle or localaly with out sending it off? |
| Rand |
Dec 2 2012, 05:03 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,415 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Dude, it's just too much pug dander. If you don't run that speedo into the triple digits at least once per week in your environment, this is typical.
I would say you could hire Troy to help, but he's more likely to let the smoke out of your clutch than burn the pug dander out of your speedo. |
TC 914-8 Speedometer issue needle acting slow and bouncy Dec 1 2012, 01:07 PM
rhodyguy search results...speedometer repair tacoma wa. for... Dec 1 2012, 02:25 PM
TC 914-8
search results...speedometer repair tacoma wa. fo... Dec 2 2012, 11:43 AM
NORD Toni I have an extra speedo if you want to borrow ... Dec 2 2012, 11:53 AM
sixnotfour whats a speedometer ??? Dec 2 2012, 02:04 PM
SLKWrx Or you could just replace it with a GPS Speedo lik... Dec 2 2012, 04:16 PM
Tom Jeff,
LOL!!, What's a speedometer? ... Dec 2 2012, 04:23 PM
Tom Sorry TC,
I just could't resist,
I loo... Dec 2 2012, 09:12 PM
TC 914-8 Alright Ding-Dongs,
Sofar Kevin has been the only... Dec 3 2012, 10:21 AM
partwerks I had this guy do some machining on mine and got h... Dec 8 2012, 05:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2026 - 04:46 AM |
