auto_cran |
Member ![]() ![]() Group: Members Posts: 56 Joined: 12-February 12 From: Dallas, Texas Member No.: 14,123 Region Association: None ![]() |
So the brake lights on our teener don't come on until the pedal is at least 1/2 pressed (or more). So I'm looking into adjusting it to come on sooner.
After removing the wooden floor board (wow - what a job!) and with the help of a mirror I can see the little screw that I need to turn. Is it best to remove the switch so I can better access the screw - or should I keep the switch in place and turn the screw? Removing the switch looks simple but I am a little concerned about the silver lever that attaches to the pedal. Also - does anyone know which way I should be turning the screw (clockwise or counterclockwise). I want to adjust it so the lights come on as soon as the lightest pressure is applied. Any help/suggestions would be appreciated. I don't want to screw up anything as the brake lights work fine, just have to really get on the brakes to see them! Thanks! Chris (auto_cran) 1974 Porsche 914 1.8 |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
The switch doesn't require adjusting.
There is a washer on the MC plunger that is sandwiched between the end of the plunger and a 15mm nut. I'm guessing that washer (which activates the switch) is in the wrong spot (often gets put back wrong making it rest further back). The armature on the switch should be touching the backside of that washer. Have a look, you should see it. In the sitting position the switch should be an open circuit. Pushing the pedal down allows the arm on the switch to move forward, closing the circuit. If that washer isn't positioned properly then you would have to depress the pedal further than usual. |
Lo-Fi Version | Time is now: 12th July 2025 - 03:07 PM |
