tumamilhem |
LUFTBRIGADE ![]() ![]() ![]() Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States ![]() |
Has this ever happened to you?
![]() ![]() Video of car on fire: https://www.facebook.com/photo.php?v=10151125433882341 This is an unfortunate, serious reality and real danger for us 914 owners that tragically happens all too often. But why and how can it be prevented? I'd like to propose three talking points that could help educate other 914 owners to make necessary precautions to preserve their cars - and their lives: 1. What causes fires in the 914 and why are they so common? 2. What precautions may be done to prevent a 914 from catching fire? 3. If your 914 does catch fire, should you try to put it out or should you stay away in case of an explosion? |
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
This is a problem for vw buses also, which don't have the plastic lines.
I would say the problem is fuel filters with worm-drive clamps dangling from braided line right next to the coil or plug wires. I had an inlet banjo come loose on a set of dells, dripping fuel. I actually shorted out the electric fuel pump for the carbs, but no fire. What you need to start a fire I think is full on spray going onto a sparkplug wire or the coil. Prevention would include keeping fuel filters out of the engine compartment, using the right clamps, securing fuel lines with zip ties, and running ethanol rated 30R9 lines, besides just replacing the plastic lines in the tunnel. |
Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,827 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California ![]() |
This is a problem for vw buses also, which don't have the plastic lines. I would say the problem is fuel filters with worm-drive clamps dangling from braided line right next to the coil or plug wires. I had an inlet banjo come loose on a set of dells, dripping fuel. I actually shorted out the electric fuel pump for the carbs, but no fire. What you need to start a fire I think is full on spray going onto a sparkplug wire or the coil. Prevention would include keeping fuel filters out of the engine compartment, using the right clamps, securing fuel lines with zip ties, and running ethanol rated 30R9 lines, besides just replacing the plastic lines in the tunnel. (IMG:style_emoticons/default/agree.gif) I also agree like Cap'n said that the fuel lines down the tunnel are rarely the problem. I replaced mine with SS just to be safe. Cheap fuel filters (in wrong and hot places), incorrect fuel hose size (and wrong type), wrong hose clamps, incorrect/lazy hose routing, etc.. Also leaky carbs. Even the stock injectors/rails are finicky and will leak if hoses are not clamped down correctly. Always go through the fuel system on a just purchased car, never know what the PO did. (IMG:style_emoticons/default/sad.gif) |
struckn |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region ![]() |
This is a problem for vw buses also, which don't have the plastic lines. I would say the problem is fuel filters with worm-drive clamps dangling from braided line right next to the coil or plug wires. I had an inlet banjo come loose on a set of dells, dripping fuel. I actually shorted out the electric fuel pump for the carbs, but no fire. What you need to start a fire I think is full on spray going onto a sparkplug wire or the coil. Prevention would include keeping fuel filters out of the engine compartment, using the right clamps, securing fuel lines with zip ties, and running ethanol rated 30R9 lines, besides just replacing the plastic lines in the tunnel. (IMG:style_emoticons/default/agree.gif) I also agree like Cap'n said that the fuel lines down the tunnel are rarely the problem. I replaced mine with SS just to be safe. Cheap fuel filters (in wrong and hot places), incorrect fuel hose size (and wrong type), wrong hose clamps, incorrect/lazy hose routing, etc.. Also leaky carbs. Even the stock injectors/rails are finicky and will leak if hoses are not clamped down correctly. Always go through the fuel system on a just purchased car, never know what the PO did. (IMG:style_emoticons/default/sad.gif) Ethanol is relatively new to fuel and a problem that may now cause the original plastic lines in the tunnel to fail. Rarely a problem in the past is not a good arguement in favor of not replacing the old plastic lines. |
Lo-Fi Version | Time is now: 20th August 2025 - 12:27 AM |
