> Speedometer Cable, Pull it or leave it?
pjf
post Dec 6 2012, 08:59 PM
I'm back to my restoration and was looking at the speedometer cable from the underside of the tunnel after removing the floor pan. I'd like to pull it out of there and then put it back in once the bodywork is done but not sure how to snake it through the tunnel once the floor pan is back on AND it looks like both ends are too large to fit through. I haven't looked closely at either end to see if the end pieces are removable. Can the speedometer cable be removed now and put back later??
balljoint
post Dec 6 2012, 11:28 PM
Don't you know aboot the 5 HP gain from dropping the speedo drive?
Pull it, it won't be a problem later to put a new one in if you must have one. They sell replacements don't they?
You can always use a GPS to gauge your speed or just calculate your own speed in your head based on the tach (IMG:style_emoticons/default/unsure.gif) and the gear you're in and your tire size.
You can do a search on this too.
Just make sure you search the garage.
Not the sandbox.
- Lo-Fi Version Time is now: 29th November 2026 - 08:19 AM
