| Harpo |
Dec 8 2012, 07:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Good evening
Is anyone using the Clewett Engineering crank fire set up? http://www.clewett.com/index.php?main_page...products_id=291 Thanks David |
| Harpo |
Dec 9 2012, 06:15 AM
I agree that the fan mounted pick up is expensive and cumbersome. I like McMarks approach with the wheel mounted behind the fan. The magnetic sensor that they use is larger (longer) that the one that McMark used so packaging behind the fan shroud may be challenging.
There are two controllers XDI & XDI-2. The XDI-2 allows for the laptop Thanks David |
Harpo Clewett Engineering - Crank fire Dec 8 2012, 07:33 PM
kg6dxn Spendy... I think there are cheaper solutions... A... Dec 8 2012, 08:00 PM
Mark Henry Not the same Mark but....
I'm assuming this i... Dec 8 2012, 08:33 PM
Mark Henry I should add running megasquirt crankfire gives yo... Dec 8 2012, 08:43 PM
McMark I've been looking into a trigger setup for six... Dec 8 2012, 10:35 PM
Mark Henry
I've been looking into a trigger setup for si... Dec 9 2012, 07:42 AM
edwin Pretty sure joe at series 9 used one on a build
Pe... Dec 8 2012, 11:44 PM
ellisor3
P... Dec 8 2012, 11:57 PM
396
Good evening
Is anyone using the Clewett Enginee... Dec 8 2012, 11:55 PM
edwin The kit in the link is for a 4cyl
I like their com... Dec 9 2012, 12:38 AM
carr914 I have used it in the Past on 2 Cars in Twin-Plug ... Dec 9 2012, 08:00 AM
Harpo My application is a 4, I was under the impression ... Dec 9 2012, 08:16 AM
Mark Henry
My application is a 4, I was under the impression... Dec 9 2012, 09:25 AM
GeorgeRud I've had the Clewitt setup on my conversion -6... Dec 9 2012, 09:30 AM
Mark Henry BTW the reason the /6 carb guys run a Clewett or m... Dec 9 2012, 09:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th July 2026 - 05:39 AM |
