| Harpo |
Dec 9 2012, 05:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Good evening everyone
For those of you with large compressors what kind of lines are you running through your garage? Thanks David |
| cary |
Dec 10 2012, 01:10 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
I'll make it even more confusing. I ran Schedule 40 PVC overhead from the compressor. But I converted to black pipe on all the pipe going down to the outlets.
I have a switch for the compressor at the door. I turn it off when I leave. So its only charged up while I'm there. |
| VaccaRabite |
Dec 10 2012, 05:13 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,840 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I'll make it even more confusing. I ran Schedule 40 PVC overhead from the compressor. But I converted to black pipe on all the pipe going down to the outlets. I have a switch for the compressor at the door. I turn it off when I leave. So its only charged up while I'm there. Unless you drain the compressor or your pipes leak or your regulator is at the compressor and not at the drop the pipes are charged all the time. Zach |
Harpo New air compressor Dec 9 2012, 05:28 PM
rudedude I put 3/4" pvc in when I did mine fully inten... Dec 9 2012, 05:40 PM
quadracerx I was thinking about using this:
http://www.rapid... Dec 9 2012, 07:30 PM
Garold Shaffer
http://www.rapi... Dec 10 2012, 06:48 AM
Dr Evil PVC, no need for metal. Dec 9 2012, 07:35 PM
914GT 3/4"copper. Metal pipe helps condense out moi... Dec 9 2012, 07:39 PM
yp914 I am getting ready to do the same thing in my base... Dec 9 2012, 07:50 PM
mrbubblehead copper. super easy to make changes and way safer t... Dec 9 2012, 08:29 PM
9146986 Plastic is much easier and cheaper, as long as you... Dec 9 2012, 08:32 PM
mrbubblehead
Plastic is much easier and cheaper, as long as yo... Dec 9 2012, 09:18 PM
shuie I just completed hooking up a 60 gallon unit with ... Dec 9 2012, 08:54 PM
wingnut86 I went black steel pipe - Chinese cast iron basica... Dec 9 2012, 09:00 PM
biosurfer1 I would never use PVC for air compressor lines. At... Dec 9 2012, 09:04 PM
76-914 3/4 pvc is certainly strong enough to handle 125ps... Dec 9 2012, 09:15 PM
G e o r g e
3/4 [color=#FF0000][i]Sch 40 or 80 pvc is certain... Dec 10 2012, 07:07 PM
Dr Evil I have been running my 80 gal through sc40 PVC at ... Dec 9 2012, 09:30 PM
edwin Our shed at home is done with copper
I'm glad ... Dec 10 2012, 05:24 AM
Zimms I went with aluminum from Garage Pak Garage Pak. W... Dec 10 2012, 06:54 AM
Mark Henry I still have to do this and it will be black pipe ... Dec 10 2012, 07:22 AM
mhuber45 I used PEX and no issues yet Dec 10 2012, 09:10 AM
Gint
Really? Have any p... Dec 10 2012, 02:13 PM
cary Zach, forgot to mention that ..................
It... Dec 10 2012, 10:17 AM
rhodyguy schedule 80. higher temps and operating pressures.... Dec 10 2012, 11:01 AM
underthetire Copper..or soft plastic line.
PVC will handle th... Dec 10 2012, 12:09 PM
r_towle I used standard rubber air hoses stapled to the w... Dec 10 2012, 02:34 PM
914GT As an FYI, here is an OSHA bulletin from several y... Dec 10 2012, 02:41 PM
charlesmac I used black pipe on mine. I have access to a pip... Dec 10 2012, 05:41 PM
zonedoubt High Density Polyethylene (HDPE) Dec 10 2012, 05:43 PM
brant black iron 3/4 gas pipe.
I installed 3 outlets an... Dec 10 2012, 07:13 PM
shuie Summit Racing sells something that is very similar... Dec 10 2012, 08:31 PM
strawman I went with 3/4" copper running along the gar... Dec 10 2012, 10:10 PM
mrbubblehead
I went with 3/4" copper running along the ga... Dec 11 2012, 01:29 PM
euro911 I'm really a CSOB. I just use extension hoses.... Dec 11 2012, 02:50 PM
Gint :agree: :lol: I just have a 25' hose attache... Dec 11 2012, 07:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th March 2026 - 06:38 AM |
