> Need info on installing intermittent wiper relays
JeffBowlsby
post Dec 10 2012, 08:43 AM
I understand the wiper relays will work for 1972-76 914s, because these cars have the brown/black wres in the main harness.
Which wiper lever switches will work with this…? I understand that a 924 switch will work. Got part numbers that work with the relay?
914.613.915.14 Stock 72-74 wiper switch?
914.613.915.15 Stock 75-76 wiper switch?
Is there a tab on the wiper switch that needs to be removed for the intermittent function? Where exactly is the tab? Any photos?
TIA
zig-n-zag
post Dec 10 2012, 01:29 PM
There is an article written in Up-Fixin der Porsche volume 9 on this.
Trim the tab on the steering column cover which will allow the
wiper switch to go downward one position from "off" to intermittent.
The intermittent relay part# is 111.955.531
Hope this helps, good luck!
Jeff Bowlsby   Need info on installing intermittent wiper relays   Dec 10 2012, 08:43 AM
SirAndy   I understand the wiper relays will work for 1972-...   Dec 10 2012, 12:11 PM
Eric_Shea   I used the 924 switch on my 74 column. The plug is...   Dec 10 2012, 01:13 PM
Elliot Cannon   I used the 924 switch on my 74 column. The plug i...   Dec 10 2012, 04:58 PM
zig-n-zag   There is an article written in Up-Fixin der Porsch...   Dec 10 2012, 01:29 PM
jim_hoyland   :agree: The 924 switch was the easiest way to go.   Dec 10 2012, 04:38 PM
Garold Shaffer   While the 924 switch will work, it is not the same...   Dec 10 2012, 05:09 PM
rdauenhauer   Doesnt explain Jeffs question, & Andys comment...   Dec 10 2012, 05:34 PM
Garold Shaffer   Doesnt explain Jeffs question, & Andys commen...   Dec 10 2012, 05:39 PM
Jeff Bowlsby   "Trim the tab on the steering column cover wh...   Dec 10 2012, 07:46 PM
914Sixer   Okay, here are the pictures. I just happened to h...   Dec 10 2012, 08:18 PM
Jeff Bowlsby   Thanks Mark, It looks like the steering column co...   Dec 11 2012, 10:51 AM
Eric_Shea   Electric lead for washer pump all in one switch....   Dec 11 2012, 11:52 AM
Eric_Shea   No, it's the switch.   Dec 11 2012, 11:56 AM
Eric_Shea   For Kevin: http://www.914world.com/bbs2/uploads_o...   Dec 11 2012, 12:01 PM
rdauenhauer   Eric are the rubber isolators still available new?...   Dec 11 2012, 02:10 PM
914Sixer   Jeff, The picture is a little off. The angle of c...   Dec 11 2012, 08:24 PM
914Sixer   Isolators are still available, about $8 each....   Dec 11 2012, 08:28 PM
a914622   So with that figured out can the programable delay...   Dec 11 2012, 08:47 PM
914Sixer   Relay part number is for a VW Rabbit.   Dec 11 2012, 08:57 PM
- Lo-Fi Version Time is now: 6th July 2025 - 11:28 AM
