JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,968 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
I understand the wiper relays will work for 1972-76 914s, because these cars have the brown/black wres in the main harness.
Which wiper lever switches will work with this…? I understand that a 924 switch will work. Got part numbers that work with the relay? 914.613.915.14 Stock 72-74 wiper switch? 914.613.915.15 Stock 75-76 wiper switch? Is there a tab on the wiper switch that needs to be removed for the intermittent function? Where exactly is the tab? Any photos? TIA |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,628 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
While the 924 switch will work, it is not the same as a 914 switch. The difference is it brings the switch closer to the steering wheel. If you have meat hooks for hands you tend to hit the switch while turning the wheel. (IMG:style_emoticons/default/dry.gif)
Lo-Fi Version | Time is now: 6th July 2025 - 12:06 PM |
