> New air compressor, copper or iron pipe
Harpo
post Dec 9 2012, 05:28 PM
Good evening everyone
For those of you with large compressors what kind of lines are you running through your garage?
Thanks
David
charlesmac
post Dec 10 2012, 05:41 PM
I used black pipe on mine. I have access to a pipe machine for cutting and threading so it was an easy choice for me, having done gas piping for many years in the HVAC business. Definitely use USA fittings if you can find them. Most plumbing supply houses here offer either, and the Chinese fittings always leak more.
Harpo   New air compressor   Dec 9 2012, 05:28 PM
rudedude   I put 3/4" pvc in when I did mine fully inten...   Dec 9 2012, 05:40 PM
quadracerx   I was thinking about using this: http://www.rapid...   Dec 9 2012, 07:30 PM
Garold Shaffer   I was thinking about using this: http://www.rapi...   Dec 10 2012, 06:48 AM
Dr Evil   PVC, no need for metal.   Dec 9 2012, 07:35 PM
914GT   3/4"copper. Metal pipe helps condense out moi...   Dec 9 2012, 07:39 PM
yp914   I am getting ready to do the same thing in my base...   Dec 9 2012, 07:50 PM
mrbubblehead   copper. super easy to make changes and way safer t...   Dec 9 2012, 08:29 PM
9146986   Plastic is much easier and cheaper, as long as you...   Dec 9 2012, 08:32 PM
mrbubblehead   Plastic is much easier and cheaper, as long as yo...   Dec 9 2012, 09:18 PM
shuie   I just completed hooking up a 60 gallon unit with ...   Dec 9 2012, 08:54 PM
wingnut86   I went black steel pipe - Chinese cast iron basica...   Dec 9 2012, 09:00 PM
biosurfer1   I would never use PVC for air compressor lines. At...   Dec 9 2012, 09:04 PM
76-914   3/4 pvc is certainly strong enough to handle 125ps...   Dec 9 2012, 09:15 PM
G e o r g e   3/4 [color=#FF0000][i]Sch 40 or 80 pvc is certain...   Dec 10 2012, 07:07 PM
Dr Evil   I have been running my 80 gal through sc40 PVC at ...   Dec 9 2012, 09:30 PM
cary   I'll make it even more confusing. I ran Schedu...   Dec 10 2012, 01:10 AM
Vacca Rabite   I'll make it even more confusing. I ran Sched...   Dec 10 2012, 05:13 AM
edwin   Our shed at home is done with copper I'm glad ...   Dec 10 2012, 05:24 AM
Zimms   I went with aluminum from Garage Pak Garage Pak. W...   Dec 10 2012, 06:54 AM
Mark Henry   I still have to do this and it will be black pipe ...   Dec 10 2012, 07:22 AM
mhuber45   I used PEX and no issues yet   Dec 10 2012, 09:10 AM
Gint   I used PEX and no issues yet Really? Have any p...   Dec 10 2012, 02:13 PM
cary   Zach, forgot to mention that .................. It...   Dec 10 2012, 10:17 AM
rhodyguy   schedule 80. higher temps and operating pressures....   Dec 10 2012, 11:01 AM
underthetire   Copper..or soft plastic line. PVC will handle th...   Dec 10 2012, 12:09 PM
r_towle   I used standard rubber air hoses stapled to the w...   Dec 10 2012, 02:34 PM
914GT   As an FYI, here is an OSHA bulletin from several y...   Dec 10 2012, 02:41 PM
charlesmac   I used black pipe on mine. I have access to a pip...   Dec 10 2012, 05:41 PM
zonedoubt   High Density Polyethylene (HDPE)   Dec 10 2012, 05:43 PM
brant   black iron 3/4 gas pipe. I installed 3 outlets an...   Dec 10 2012, 07:13 PM
shuie   Summit Racing sells something that is very similar...   Dec 10 2012, 08:31 PM
strawman   I went with 3/4" copper running along the gar...   Dec 10 2012, 10:10 PM
mrbubblehead   I went with 3/4" copper running along the ga...   Dec 11 2012, 01:29 PM
euro911   I'm really a CSOB. I just use extension hoses....   Dec 11 2012, 02:50 PM
Gint   :agree: :lol: I just have a 25' hose attache...   Dec 11 2012, 07:47 PM
- Lo-Fi Version Time is now: 7th March 2026 - 06:38 AM
