JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,969 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
I understand the wiper relays will work for 1972-76 914s, because these cars have the brown/black wres in the main harness.
Which wiper lever switches will work with this…? I understand that a 924 switch will work. Got part numbers that work with the relay? 914.613.915.14 Stock 72-74 wiper switch? 914.613.915.15 Stock 75-76 wiper switch? Is there a tab on the wiper switch that needs to be removed for the intermittent function? Where exactly is the tab? Any photos? TIA |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,186 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Okay, here are the pictures. I just happened to have some columns out. You simply cut the plastic bottom tab off on the switch.
Attached image(s) ![]() ![]() |
Lo-Fi Version | Time is now: 6th July 2025 - 07:06 PM |
