| Harpo |
Dec 9 2012, 05:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Good evening everyone
For those of you with large compressors what kind of lines are you running through your garage? Thanks David |
| strawman |
Dec 10 2012, 10:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 891 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California
I went with 3/4" copper running along the garage ceiling with three drops and ball valves at each drop to drain water. I put in 80 feet total, and certainly could have saved a bunch of $$ using PVC, but why risk injury? I'm a CSOB, but I'm not willing to risk losing my eyesight if/when the PVC shatters...
| mrbubblehead |
Dec 11 2012, 01:29 PM
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
I went with 3/4" copper running along the garage ceiling with three drops and ball valves at each drop to drain water. I put in 80 feet total, and certainly could have saved a bunch of $$ using PVC, but why risk injury? I'm a CSOB, but I'm not willing to risk losing my eyesight if/when the PVC shatters... (IMG:style_emoticons/default/agree.gif) |
Harpo New air compressor Dec 9 2012, 05:28 PM
rudedude I put 3/4" pvc in when I did mine fully inten... Dec 9 2012, 05:40 PM
quadracerx I was thinking about using this:
http://www.rapid... Dec 9 2012, 07:30 PM
Garold Shaffer
http://www.rapi... Dec 10 2012, 06:48 AM
Dr Evil PVC, no need for metal. Dec 9 2012, 07:35 PM
914GT 3/4"copper. Metal pipe helps condense out moi... Dec 9 2012, 07:39 PM
yp914 I am getting ready to do the same thing in my base... Dec 9 2012, 07:50 PM
mrbubblehead copper. super easy to make changes and way safer t... Dec 9 2012, 08:29 PM
9146986 Plastic is much easier and cheaper, as long as you... Dec 9 2012, 08:32 PM
mrbubblehead
Plastic is much easier and cheaper, as long as yo... Dec 9 2012, 09:18 PM
shuie I just completed hooking up a 60 gallon unit with ... Dec 9 2012, 08:54 PM
wingnut86 I went black steel pipe - Chinese cast iron basica... Dec 9 2012, 09:00 PM
biosurfer1 I would never use PVC for air compressor lines. At... Dec 9 2012, 09:04 PM
76-914 3/4 pvc is certainly strong enough to handle 125ps... Dec 9 2012, 09:15 PM
G e o r g e
3/4 [color=#FF0000][i]Sch 40 or 80 pvc is certain... Dec 10 2012, 07:07 PM
Dr Evil I have been running my 80 gal through sc40 PVC at ... Dec 9 2012, 09:30 PM
cary I'll make it even more confusing. I ran Schedu... Dec 10 2012, 01:10 AM
Vacca Rabite
I'll make it even more confusing. I ran Sched... Dec 10 2012, 05:13 AM
edwin Our shed at home is done with copper
I'm glad ... Dec 10 2012, 05:24 AM
Zimms I went with aluminum from Garage Pak Garage Pak. W... Dec 10 2012, 06:54 AM
Mark Henry I still have to do this and it will be black pipe ... Dec 10 2012, 07:22 AM
mhuber45 I used PEX and no issues yet Dec 10 2012, 09:10 AM
Gint
Really? Have any p... Dec 10 2012, 02:13 PM
cary Zach, forgot to mention that ..................
It... Dec 10 2012, 10:17 AM
rhodyguy schedule 80. higher temps and operating pressures.... Dec 10 2012, 11:01 AM
underthetire Copper..or soft plastic line.
PVC will handle th... Dec 10 2012, 12:09 PM
r_towle I used standard rubber air hoses stapled to the w... Dec 10 2012, 02:34 PM
914GT As an FYI, here is an OSHA bulletin from several y... Dec 10 2012, 02:41 PM
charlesmac I used black pipe on mine. I have access to a pip... Dec 10 2012, 05:41 PM
zonedoubt High Density Polyethylene (HDPE) Dec 10 2012, 05:43 PM
brant black iron 3/4 gas pipe.
I installed 3 outlets an... Dec 10 2012, 07:13 PM
shuie Summit Racing sells something that is very similar... Dec 10 2012, 08:31 PM
euro911 I'm really a CSOB. I just use extension hoses.... Dec 11 2012, 02:50 PM
Gint :agree: :lol: I just have a 25' hose attache... Dec 11 2012, 07:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th March 2026 - 06:39 AM |
