JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,968 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
I understand the wiper relays will work for 1972-76 914s, because these cars have the brown/black wres in the main harness.
Which wiper lever switches will work with this…? I understand that a 924 switch will work. Got part numbers that work with the relay? 914.613.915.14 Stock 72-74 wiper switch? 914.613.915.15 Stock 75-76 wiper switch? Is there a tab on the wiper switch that needs to be removed for the intermittent function? Where exactly is the tab? Any photos? TIA |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,186 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Jeff,
The picture is a little off. The angle of cover for the ignition switch is in the corner. You just cut the bottom of the plastic tab on the wiper switch. 1st picture show switch with not cut off. You can take a knife and cut tab off with column in car, or you can cut it off smooth be for installing switch. |
Lo-Fi Version | Time is now: 6th July 2025 - 11:39 AM |
