> Down In A Blaze Of Unglory - 914s on FIRE!, It can be pretty common, unfortunately. What causes the 914 to catch fire so easily, how to prevent it from happening and what to do if it does happen
tumamilhem
post Dec 4 2012, 02:32 PM
LUFTBRIGADE
Has this ever happened to you?
Video of car on fire: https://www.facebook.com/photo.php?v=10151125433882341
This is an unfortunate, serious reality and real danger for us 914 owners that tragically happens all too often. But why and how can it be prevented?
I'd like to propose three talking points that could help educate other 914 owners to make necessary precautions to preserve their cars - and their lives:
1. What causes fires in the 914 and why are they so common?
2. What precautions may be done to prevent a 914 from catching fire?
3. If your 914 does catch fire, should you try to put it out or should you stay away in case of an explosion?
Jgilliam914
post Dec 12 2012, 02:36 PM
I had a 72 with a 1.7 go up in smoke and flames in my garage in 1986. The magnesium was put out by a foam fire suppressant. The sparks and the color of the magnesium burning was pretty and it popped like popcorn. I am thankful the car had only had a gallon of gas in it. It was up on stands at the time. The fire Marshall was called in due to the insurance co. thinking I torched it. I had issues with the starter not disengaging and he thought that the heat from that with the fuel lines so close one ignited the other. Until then I had a 9 yr old nephew who had been known to light fires staying with me I thought he may have playing with matches. What was funny about this is that the Insurance investigator who thought I may have torched it ended up being my father in law 26 years later
tumamilhem   Down In A Blaze Of Unglory - 914s on FIRE!   Dec 4 2012, 02:32 PM
tumamilhem   I'll go first. Fortunately, this has never ha...   Dec 4 2012, 02:35 PM
billh1963   Wonder how much he wants for those fuchs? :lol4:   Dec 4 2012, 02:43 PM
tumamilhem   Oh that's just wrong. :/ The guy said he had ...   Dec 4 2012, 02:46 PM
zymurgist   The plastic fuel lines in the tunnel are 40 years ...   Dec 4 2012, 02:51 PM
tumamilhem   Where can I find these stainless fuel lines and ho...   Dec 4 2012, 02:56 PM
JawjaPorsche   Pelican Parts sells them. Where can I find these...   Dec 4 2012, 03:00 PM
Cairo94507   Tangerine racing: http://tangerineracing.com/stain...   Dec 4 2012, 03:01 PM
zymurgist   Tangerine racing: http://tangerineracing.com/stai...   Dec 4 2012, 03:24 PM
tumamilhem   What is a basic fire suppression system? Where can...   Dec 4 2012, 03:03 PM
nathansnathan   This is a problem for vw buses also, which don...   Dec 4 2012, 03:11 PM
tumamilhem   This is a problem for vw buses also, which don...   Dec 4 2012, 03:17 PM
nathansnathan   This is a problem for vw buses also, which don...   Dec 4 2012, 03:58 PM
tumamilhem   [quote name='tumamilhem' post='1778349' date='Dec...   Dec 4 2012, 04:28 PM
Cap'n Krusty   [quote name='tumamilhem' post='1778349' date='De...   Dec 4 2012, 05:53 PM
Hammy   This is a problem for vw buses also, which don...   Dec 4 2012, 05:04 PM
struckn   This is a problem for vw buses also, which don...   Dec 5 2012, 07:58 PM
Cap'n Krusty   This has been a problem since the cars came onto t...   Dec 4 2012, 03:25 PM
jimkelly   my understanding is that when magnesium catches fi...   Dec 4 2012, 03:45 PM
Johny Blackstain   Magnesium can burn under water so if it lights the...   Dec 4 2012, 03:50 PM
tumamilhem   Magnesium can burn under water so if it lights th...   Dec 4 2012, 04:24 PM
boogie_man   I'm not sure but, did you see the car lurching...   Dec 4 2012, 03:52 PM
Cairo94507   I have yet to locate the system that will be insta...   Dec 4 2012, 04:04 PM
tumamilhem   And what size 30R9 lines for 2.0 stock?   Dec 4 2012, 04:30 PM
nathansnathan   And what size 30R9 lines for 2.0 stock? Here...   Dec 4 2012, 05:12 PM
rgolia   I lost 8 gallons of gas in 3 city blocks in the so...   Dec 4 2012, 04:48 PM
ellisor3   Here is link to some fire supression systems. htt...   Dec 4 2012, 05:10 PM
brant   my understanding is that when magnesium catches f...   Dec 4 2012, 05:32 PM
nathansnathan   I've seen pics where the magnesium fan housing...   Dec 4 2012, 05:57 PM
tumamilhem   Damn, that's scary. :/   Dec 4 2012, 06:32 PM
Bruce Hinds   Dang, all this chatter and nobody mentioned the ig...   Dec 4 2012, 06:47 PM
Katmanken   I actually watched one go up in flames while it wa...   Dec 4 2012, 07:06 PM
tumamilhem   I actually watched one go up in flames while it w...   Dec 4 2012, 08:44 PM
URY914   The fan housing on a Type IV is aluminum. It melts...   Dec 4 2012, 07:14 PM
RickS   A halon extinguisher is the next best thing to a f...   Dec 4 2012, 09:05 PM
rdauenhauer   This has been a problem since the cars came onto t...   Dec 4 2012, 09:30 PM
Dr Evil   I have never been able to ignite tranny cases. I h...   Dec 4 2012, 09:52 PM
carr914   Magnesium can burn under water so if it lights th...   Dec 4 2012, 10:04 PM
GeorgeRud   Halon has the least cleanup, but foam is probably ...   Dec 4 2012, 10:07 PM
tumamilhem   Where is the fuel pump located on a '74? I hav...   Dec 4 2012, 10:21 PM
GeorgeRud   74 is in back under passenger side engine shelf.   Dec 4 2012, 10:28 PM
tumamilhem   So it should be moved then I suppose? What do I ne...   Dec 4 2012, 10:44 PM
stateofidleness   So it should be moved then I suppose? What do I n...   Dec 4 2012, 11:25 PM
montoya 73 2.0   It looks as though they used foam on that Teener. ...   Dec 4 2012, 11:29 PM
maxwelj   To answer the question about catching fire while p...   Dec 5 2012, 02:52 PM
76-914   I'll add one, albeit in "left field...   Dec 5 2012, 03:59 PM
Ductech   I remember a v8 conversion that caught fire in a p...   Dec 5 2012, 04:12 PM
ClayPerrine   This is from personal experience...... Betty and ...   Dec 5 2012, 06:10 PM
tumamilhem   Suppression system aside do to high cost, what kin...   Dec 6 2012, 04:20 PM
nathansnathan   Suppression system aside do to high cost, what ki...   Dec 6 2012, 08:10 PM
iamchappy   SS lines are a must, and this is piece of mind....   Dec 6 2012, 04:25 PM
Dr Evil   B is what you need for gasoline. C is for electric...   Dec 6 2012, 08:44 PM
nathansnathan   B is what you need for gasoline. C is for electri...   Dec 6 2012, 09:01 PM
carr914   Ethanol is relatively new to fuel and a problem t...   Dec 6 2012, 08:51 PM
Dr Evil   Bringing up my old Naval Firefighter knowledge :)   Dec 6 2012, 09:05 PM
Kirmizi   Bringing up my old Naval Firefighter knowledge :)...   Dec 6 2012, 10:01 PM
scotty b   Bringing up my old Naval Firefighter knowledge :...   Dec 6 2012, 10:11 PM
Dr Evil   No, I capitalized the propped nouns do you would k...   Dec 7 2012, 08:33 AM
Madswede   He did say "Naval" not "navel...   Dec 7 2012, 01:21 PM
Porsche930dude   the factory seam sealer puddy seems to be very fla...   Dec 7 2012, 06:32 PM
montoya 73 2.0   I replaced my home extinguishers (powder) to CO2. ...   Dec 7 2012, 10:48 PM
Dr Evil   CO2 removes O2 and heat from the equation so as lo...   Dec 8 2012, 12:07 PM
Drums66   .....Pass me another hotdog.......mine got burned...   Dec 8 2012, 06:30 PM
gaspump   Now you guys have me all shook up. I'm going t...   Dec 8 2012, 08:57 PM
Porschef   The factory fuel lines are a combination of nylon ...   Dec 9 2012, 07:39 AM
jim_hoyland   Some fires look like there's nothing that will...   Dec 9 2012, 08:48 AM
tumamilhem   Damn. That's heartbreaking.   Dec 9 2012, 10:17 AM
Katmanken   I really hope nobody is using cable ties to secure...   Dec 9 2012, 10:47 AM
john_g   Somebody send a photo of a good quality clamp, ple...   Dec 9 2012, 12:18 PM
nathansnathan   I really hope nobody is using cable ties to secur...   Dec 9 2012, 02:06 PM
Katmanken   Here is the one supplied in the factory recall to ...   Dec 9 2012, 01:34 PM
tumamilhem   Not a good use of a 914 fire, but certainly more p...   Dec 12 2012, 01:10 PM
tumamilhem   Maybe he could part out the rest. Look like it...   Dec 12 2012, 01:11 PM
Jgilliam914   I had a 72 with a 1.7 go up in smoke and flames i...   Dec 12 2012, 02:36 PM
914_teener   I had a 72 with a 1.7 go up in smoke and flames ...   Dec 12 2012, 02:52 PM
tumamilhem   I had a 72 with a 1.7 go up in smoke and flames ...   Dec 12 2012, 03:01 PM
Vacca Rabite   I had a 72 with a 1.7 go up in smoke and flames...   Dec 12 2012, 08:48 PM
- Lo-Fi Version Time is now: 20th August 2025 - 12:33 AM
