larss |
Member ![]() ![]() Group: Members Posts: 431 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia ![]() |
When working with getting rid of vibrations from the engine (which succeded when I put back my old engine rubber mounts instead of the new 911 ones) I noticed that the clutch arm is wobbling a bit (approx 1mm in its outer end) when cranking the engine, is this normal?
Through inspection holes I can see flywheel and clutch running straight non wobbling at cranking. The car is all original tail shift 1,7. /Lars |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,245 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
When working with getting rid of vibrations from the engine (which succeded when I put back my old engine rubber mounts instead of the new 911 ones) I noticed that the clutch arm is wobbling a bit (approx 1mm in its outer end) when cranking the engine, is this normal? There is a plastic bushing on the arm where it sits on the pivot that is bolted to the case. My guess is your bushing has disintegrated allowing the arm to wobble. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 6th July 2025 - 06:41 PM |
