> How did you learn to TIG weld?, Post your tips and stories.
FourBlades
post Dec 17 2012, 10:14 PM
From Wreck to Rockin
I have been thinking about learning to TIG weld for a few years and took the plunge.
I bought the Eastwood AC/DC unit and have been playing with it for a few weeks.
I did all the obvious learning stuff, watching you tube videos, reading about it.
I like WeldingTipsAndTricks.com videos.
At first I just could not see what was going on well enough so I bought a 3x magnifier for my helmet. I also had a lot of trouble with fogging so I got some FogTech drops which completely stopped the fogging. These tips made it a lot easier to see the arc and the puddle.
Now if I could just stop touching the tungsten to the puddle it would be nice.
I'd like to be able to TIG thin metal to limit heat input, do good roll bar welding, and make stuff from aluminum. I know this will take a lot of time and practice.
What tips really helped you, what practice exercises did you do, what war stories do you have?
Thanks,
John
FourBlades
post Dec 18 2012, 06:23 AM
Thanks folks!
I am using the foot pedal to start and control the heat.
It has a knob on the pedal which is supposed to set the maximum amps with the pedal fully depressed. It does seem to make a big difference what I set it to.
You can see the unit does a high frequency start with a long thin arc and humming sound before the main arc comes on. I try to never touch the electrode to the metal but that seems to be my downfall right now.
I will keep at it... (IMG:style_emoticons/default/welder.gif)
John
FourBlades   How did you learn to TIG weld?   Dec 17 2012, 10:14 PM
stugray   Some quick tips for you: To learn control of the ...   Dec 17 2012, 10:43 PM
Elliot Cannon   You'll get real good at sharpening the tungste...   Dec 17 2012, 10:50 PM
McMark   Since my first exposure to welding was OxyAcetelen...   Dec 17 2012, 10:53 PM
FourBlades   Since my first exposure to welding was OxyAcetele...   Dec 17 2012, 11:05 PM
Elliot Cannon   :agree: Yeah. That's pretty much what I meant...   Dec 17 2012, 10:57 PM
McMark   No copper. No filler rod. You'll have some pro...   Dec 17 2012, 11:14 PM
nathansnathan   Some things to note, you should hold the electrode...   Dec 17 2012, 11:40 PM
FourBlades   Thanks folks! I am using the foot pedal to st...   Dec 18 2012, 06:23 AM
scotty b   I'm tigging 1/4 on a 911 right now. this is th...   Dec 18 2012, 06:38 AM
scotty b   also starrt out with some scrap working on your pu...   Dec 18 2012, 06:40 AM
SUNAB914   diping the rod That's what Doc Evil said. :WT...   Dec 18 2012, 06:52 AM
FourBlades   Thanks Scotty! So really tight fit up is impo...   Dec 18 2012, 10:01 AM
9146986   If you are just learning, I'd suggest learning...   Dec 18 2012, 10:22 AM
ConeDodger   Welding clinic Mark?   Dec 18 2012, 10:51 AM
The Metal Surgeon   Practice oxy acet welding first. I went to Coventr...   Dec 18 2012, 11:03 AM
Black22   My 20yr old cousins work...damn kids!!...   Dec 18 2012, 11:08 AM
ruby914   I took welding in high school. I think I was very ...   Dec 18 2012, 11:18 AM
andys   I now wear glasses, just seeing the puddle is my ...   Dec 18 2012, 12:23 PM
stugray   http://www.914world.com/bbs2/uploads/post-8290-1...   Dec 18 2012, 12:01 PM
Black22   http://www.914world.com/bbs2/uploads/post-8290-...   Dec 18 2012, 12:22 PM
FourBlades   I will look into the oxy/acetylene welding. Is it...   Dec 18 2012, 02:39 PM
The Metal Surgeon   Tig welding doesn't leave a brittle weld on sh...   Dec 18 2012, 05:05 PM
scotty b   Tig welding doesn't leave a brittle weld on s...   Dec 18 2012, 09:09 PM
okieflyr   My strategy is to sharpen 4-5 electrodes at a time...   Dec 18 2012, 06:49 PM
FourBlades   Kevin, That is a great tip to sharpen more than o...   Dec 18 2012, 09:02 PM
FourBlades   Scotty, you will definitely get there... WOT: The...   Dec 18 2012, 09:21 PM
strawman   WOT: The HAMB is the bomb for crazy metal work ru...   Dec 18 2012, 11:57 PM
sean_v8_914   the oxy practice tip is good. i also use a little ...   Dec 19 2012, 09:33 AM
mr914   I signed up for a class at the local community col...   Dec 19 2012, 03:39 PM
stugray   A friend of mine was fusion welding together a 1...   Dec 19 2012, 05:09 PM
rick 918-S   Lots of great suggestions here. Like many others h...   Dec 20 2012, 12:08 AM
stugray   rick - NICE experience. I like the flexing, floati...   Dec 20 2012, 12:34 AM
rick 918-S   rick - NICE experience. I like the flexing, float...   Dec 20 2012, 08:43 AM
FourBlades   Mark's comment really struck a nerve with me. ...   Dec 20 2012, 09:21 AM
jd74914   It's all about practice time. I learned the ba...   Dec 21 2012, 08:19 AM
stugray   Another trick I learned from welding that most wou...   Dec 23 2012, 12:29 AM
- Lo-Fi Version Time is now: 17th July 2025 - 09:01 PM
