FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
I have been thinking about learning to TIG weld for a few years and took the plunge.
I bought the Eastwood AC/DC unit and have been playing with it for a few weeks. ![]() I did all the obvious learning stuff, watching you tube videos, reading about it. I like WeldingTipsAndTricks.com videos. At first I just could not see what was going on well enough so I bought a 3x magnifier for my helmet. I also had a lot of trouble with fogging so I got some FogTech drops which completely stopped the fogging. These tips made it a lot easier to see the arc and the puddle. Now if I could just stop touching the tungsten to the puddle it would be nice. I'd like to be able to TIG thin metal to limit heat input, do good roll bar welding, and make stuff from aluminum. I know this will take a lot of time and practice. What tips really helped you, what practice exercises did you do, what war stories do you have? Thanks, John |
FourBlades |
Thanks Scotty! So really tight fit up is important, which makes sense. Do you start the puddle on one side then move across the joint to fuse the sides together or do you start in the middle of the joint? When I try to start in the middle of the joint, all I end up with is a hole. (IMG:style_emoticons/default/sad.gif) John |
Lo-Fi Version | Time is now: 17th July 2025 - 08:49 PM |
