FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
I have been thinking about learning to TIG weld for a few years and took the plunge.
I bought the Eastwood AC/DC unit and have been playing with it for a few weeks. ![]() I did all the obvious learning stuff, watching you tube videos, reading about it. I like WeldingTipsAndTricks.com videos. At first I just could not see what was going on well enough so I bought a 3x magnifier for my helmet. I also had a lot of trouble with fogging so I got some FogTech drops which completely stopped the fogging. These tips made it a lot easier to see the arc and the puddle. Now if I could just stop touching the tungsten to the puddle it would be nice. I'd like to be able to TIG thin metal to limit heat input, do good roll bar welding, and make stuff from aluminum. I know this will take a lot of time and practice. What tips really helped you, what practice exercises did you do, what war stories do you have? Thanks, John |
The Metal Surgeon |
Member ![]() ![]() Group: Members Posts: 128 Joined: 8-September 12 From: Denver,Colorado Member No.: 14,902 Region Association: None ![]() |
Tig welding doesn't leave a brittle weld on sheet metal,mig does in my opinion
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Tig welding doesn't leave a brittle weld on sheet metal,mig does in my opinion (IMG:style_emoticons/default/agree.gif) Gas will leave the softest weld, BUT if you aren't sufficient with it, it will also warp the worst. As far as tig goes, no I do not weld long lengths even in tig. Get the tight fit and spot it. I typically end up with spot welds about 3/4 of an inch apart before running any kind of a bead, but, I also am nowhere near the level of the metal surgeon. I have watched his work on the HAMB for a few years now and that level, is what I aspire to be soon (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 17th July 2025 - 08:43 PM |
