rear trunk latch |
rear trunk latch |
last337 |
Dec 19 2012, 05:36 PM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
I have tried everything to get into this thing. The rear trunk latch is obviously destroyed and I am just about at the point of drilling the thing out to get inside and install another. I tried opening up the underside access panel just above the transmission but that wont budge either.
Has anyone ever drilled on out? And if so, what was your technique and how did you get the sucker open after? I have seen the latches posted on ebay for about 10 bucks so I dont mind replacing just wondering if that is my ticket to get inside. Any help is appreciated (IMG:style_emoticons/default/biggrin.gif) |
bandjoey |
Dec 19 2012, 05:42 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
What's wrong? Can't get in? Lock frozen? Lost the key? More info please.
last337 |
Dec 19 2012, 05:49 PM
What's wrong? Can't get in? Lock frozen? Lost the key? More info please. The key will turn just fine. This may be a stupid question but unlocked is when the key is vertical correct? Anyways, if the key is horizontal or vertical the result is the same, you can press the button but feel no tension in the button and nothing happens. Sometimes when you push on the trunk you can feel it lock back completely again and then you may feel something at the very bottom when you push button again. |
Lo-Fi Version | Time is now: 10th June 2024 - 03:53 PM |
