| Chris H. |
Dec 19 2012, 04:33 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,079 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
I'm doing a 3.3L Subie conversion with a WRX trans using Ian's kit. Not sure the 90 lb rear springs are going to cut it, and they need to be changed anyway. What spring rate would be best? 250 hpish flat 6. Weighs about 350 lbs I think. Don't want my teeth rattled out, just want them to be strong enough for the job. Maybe the stock springs are OK I just don't know.
Build thread coming soon!~ |
| jimkelly |
Dec 20 2012, 02:28 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i think i've read one say that a rear sway bar feels like an increase in spring rate.
these look nice http://www.ground-control-store.com/produc...hp/II=76/CA=217 |
| andys |
Dec 20 2012, 03:36 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
i think i've read one say that a rear sway bar feels like an increase in spring rate. these look nice http://www.ground-control-store.com/produc...hp/II=76/CA=217 Those Ground Control springs and perches are a good value for the money. I have a set on my car. 200# springs on a V8 conversion. Andys Attached thumbnail(s) |
Chris H. Spring rates for a 3.3L Subie conversion Dec 19 2012, 04:33 PM
wingnut86 Chris,
I'm only looking at a 2.5L SOHC Subie ... Dec 19 2012, 04:38 PM
Travis Neff What do you have in the front, torsion bar size an... Dec 19 2012, 05:02 PM
Chris H. Travis,
Stock setup now... not even a sway bar b... Dec 19 2012, 06:21 PM
kg6dxn I have 200lb progressive springs on mine. From the... Dec 19 2012, 06:25 PM
mittelmotor I think 200-lb. springs would be nice, paired with... Dec 20 2012, 02:00 AM
Van914 When I did my 3.0 conversion I used:
21 mm Torson ... Dec 20 2012, 05:59 AM
Travis Neff I would suggest for a decent ride and improved per... Dec 20 2012, 10:40 AM
Chris H. Thanks guys! Great advice. Those Ground Cont... Dec 20 2012, 04:33 PM
nsyr I have the svx engine with suby trans.
initially i... Dec 20 2012, 06:13 PM
nsyr Double post Dec 20 2012, 06:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:03 PM |
