> New Work Bench, Top Suggestions?
jfort
post Dec 20 2012, 11:47 AM
I am going to make a new work bench this winter. Maybe 30" by 16'. 4 by 4's. drawers and a shelf across the bottom. A vise. I am just your typical once-in-while car project and home project type guy.
Don't know what to do for the top. I see places make butcher block. I put formica-type stuff on top of 3/4" plywood one time. I've though about a sheet of metal, but something tells me not to do that.
Suggestions? Any other suggestion about a work bench would be appreciated, too. For example, I've thought about getting 2 or 3 half-sized metal shop drawer thinks, bolting them together and putting a work bench top on that. What do you think?
URY914
post Dec 20 2012, 07:30 PM
Working as a project manager for a construction company has some advantages. (IMG:style_emoticons/default/smile.gif)
jfort   New Work Bench   Dec 20 2012, 11:47 AM
URY914   If you want a wood top, try a building supply that...   Dec 20 2012, 11:52 AM
Andyrew   If you want a wood top, try a building supply tha...   Jan 9 2013, 10:25 PM
two-strokejohn   I like metal tops on my workbenches, because they ...   Dec 20 2012, 11:57 AM
jfort   what gauge stainless? how did you hold it down?   Dec 20 2012, 12:04 PM
mwyatt   I used a sheet of stainless over MDF. Don't r...   Dec 20 2012, 12:33 PM
two-strokejohn   what gauge stainless? how did you hold it down? ...   Dec 20 2012, 03:07 PM
kg6dxn   I have a galvanized steel skin on one of mine. I f...   Dec 20 2012, 12:40 PM
DBCooper   It depends a lot on what you want to use it for. ...   Dec 20 2012, 12:44 PM
URY914   Gint's solid core door suggestion is a good...   Dec 20 2012, 01:24 PM
DBCooper   Gint's solid core door suggestion is a goo...   Dec 20 2012, 01:55 PM
Gint   Gint's solid core door suggestion is a good ...   Dec 20 2012, 11:16 PM
underthetire   Check your local C/L first. Sometimes it's rea...   Dec 20 2012, 12:44 PM
abnrdo   I have this one from Sears. 8 Ft Butcher Block B...   Dec 20 2012, 01:10 PM
Vacca Rabite   Plywood. I have made bunches of work benches and t...   Dec 20 2012, 01:12 PM
7TPorsh   You can but stainless steel flashing for roofs in ...   Dec 20 2012, 01:13 PM
URY914   I also have a bench top made from a hollow metal d...   Dec 20 2012, 01:26 PM
stugray   I was going to sugget the hollow metal door also -...   Dec 20 2012, 01:36 PM
7TPorsh   I was going to sugget the hollow metal door also ...   Dec 20 2012, 01:38 PM
dpires914   I was going to sugget the hollow metal door also ...   Dec 20 2012, 07:27 PM
Dasnowman   I was going to sugget the hollow metal door also ...   Dec 21 2012, 01:00 AM
Elliot Cannon   I laminated two 3/4 inch sheets of plywood. Rout...   Dec 20 2012, 01:44 PM
OU8AVW   these look cool http://www.creativeshelters.com/2...   Dec 20 2012, 01:53 PM
Mark Henry   My main bench is 3 heavy industrial steel doors, I...   Dec 20 2012, 03:18 PM
Travis Neff   I did mine with 3/4 plywood and covered in in 20G ...   Dec 20 2012, 03:27 PM
Jon H.   I picked up used 5'x7' x 1/4 plate steel t...   Dec 20 2012, 04:25 PM
yp914   I agree a solid core wood door is the best table t...   Dec 20 2012, 04:38 PM
scotty b   If you want to do a little elbow work, go to a lo...   Dec 20 2012, 04:38 PM
MDG   If you want to do a little elbow work, go to a l...   Dec 20 2012, 07:20 PM
scotty b   If you want to do a little elbow work, go to a ...   Dec 20 2012, 08:00 PM
MDG   [quote name='MDG' post='1787541' date='Dec 20 201...   Dec 21 2012, 12:11 PM
Scott S   I used plywood, and then covered it with the peel ...   Dec 20 2012, 05:19 PM
zonedoubt   Salvaged kitchen laminate countertop. Mine has sto...   Dec 20 2012, 05:48 PM
strawman   Salvaged kitchen laminate countertop. Mine has st...   Dec 20 2012, 06:57 PM
Tom   Here is a pic of my work area. Not as large as I w...   Dec 20 2012, 07:19 PM
URY914   Here is a shot off my vise mounted on my hollow me...   Dec 20 2012, 07:25 PM
URY914   And my grinder mounted my solid core door OAK .......   Dec 20 2012, 07:26 PM
URY914   Drill press is on a peice of plastic laminate coun...   Dec 20 2012, 07:28 PM
URY914   Working as a project manager for a construction co...   Dec 20 2012, 07:30 PM
dpires914   I am going to make a new work bench this winter. ...   Dec 20 2012, 07:43 PM
bigkensteele   http://www.harborfreight.com/60-inch-workbench-934...   Dec 20 2012, 08:07 PM
oldschool   Found this old kitchen table on the side of a road...   Dec 20 2012, 08:55 PM
euro911   This is a freebie I picked up from one of Joe Shar...   Dec 20 2012, 09:04 PM
cwpeden   I covered mine with cheap laminate flooring from h...   Dec 21 2012, 01:17 AM
dian   i did exactly the same. besides i poured this one...   Dec 21 2012, 10:17 AM
rnellums   I love this thread   Dec 21 2012, 10:31 AM
balljoint   I am with scotty on the freebies. I found some gr...   Dec 21 2012, 10:48 AM
DBCooper   I am with scotty on the freebies. I found some g...   Dec 21 2012, 11:22 AM
MDG   Let's see, where are you from again? Good, ...   Dec 21 2012, 12:13 PM
Mark Henry   I am with scotty on the freebies. I found some g...   Dec 21 2012, 05:40 PM
struckn   Here's a PORTABLE HEAVY TABLE WORK BENCH 4...   Dec 21 2012, 10:56 AM
rwilner   Here's a PORTABLE HEAVY TABLE WORK BENCH 4...   Dec 21 2012, 08:30 PM
struckn   [quote name='struckn' post='1787937' date='Dec 21...   Dec 22 2012, 06:28 PM
mhuber45   i went to our local factory 2nd's building sup...   Dec 21 2012, 11:26 AM
Brian_Boss   All I can add to all the good ideas above is to sa...   Dec 21 2012, 05:11 PM
Gint   Eh... mine has crap on it all the time. Might as ...   Dec 21 2012, 05:31 PM
Travis Neff   :)   Dec 22 2012, 11:17 AM
stugray   You mean like this: (its sort of a where's w...   Dec 22 2012, 04:01 PM
Gint   :bump: This thread is much too young to die...   Dec 23 2012, 11:41 AM
Elliot Cannon   You can find great ideas here. http://www.garag...   Dec 23 2012, 12:16 PM
euro911   Yeah. Here you go ... roll away and bench in one m...   Dec 23 2012, 01:29 PM
jfort   finally just got back on line to see if anyone res...   Dec 27 2012, 02:26 PM
rfuerst911sc   Built mine out of 2x6's and over 16 ' long...   Dec 28 2012, 04:58 AM
7TPorsh   how about some shelving and cabinet ideas? I have...   Dec 28 2012, 12:33 PM
euro911   If you're on a budget and just need some inexp...   Dec 28 2012, 09:05 PM
cwpeden   Down the street from my place is a government surp...   Jan 8 2013, 11:08 PM
Michelj13   Here is mine. A little messy, but surprising what ...   Jan 9 2013, 09:48 AM
7TPorsh   I love this thread. Someone should start on on gar...   Jan 9 2013, 10:13 AM
charliew   I picked up a good metal bench with a top shelf fr...   Jan 9 2013, 03:23 PM
montoya 73 2.0   I needed a desk but wanted a workbench so I built ...   Jan 9 2013, 07:29 PM
Gint   This thread... influenced me to clean up my bench ...   Jan 9 2013, 11:16 PM
PanelBilly   Find a local office furniture manufacturer. They...   Jan 10 2013, 12:26 AM
euro911   Long overdue here. Not far behind you, Mike :idea:...   Jan 10 2013, 12:29 AM
stateofidleness   looks like a '78/'79ish Peavey Mace VT Ser...   Jan 10 2013, 12:35 AM
euro911   looks like a '78/'79ish Peavey Mace VT Ser...   Jan 10 2013, 01:08 AM
- Lo-Fi Version Time is now: 13th July 2025 - 10:03 AM
