Relay kit |
Relay kit |
partwerks |
Dec 20 2012, 07:38 AM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
With the pilot driving lights in, and the upgraded Hella, 55W/100W lamps in, do I need a relay for the Pilot lights, and the head lamps, or just the head lamps? Is there a round relay that I could swap out with the one on the fuse block that would handle the work load, or do I need to find a relay kit in addition to that??
Tom |
Dec 20 2012, 07:31 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
It would take a load off the headlight switch if you did put the proper relays in.
Try Rallylights.com for kits/info. Tom |
partwerks |
Dec 21 2012, 07:14 AM
It would take a load off the headlight switch if you did put the proper relays in. Try Rallylights.com for kits/info. Tom Well, if I understood him right, my electrician said, that maybe a person could find a junk relay and use the sockets on it and retrofit a rectangular relay to it if there is room above the fuse block for clearance? Adapt the new to the old? |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:07 AM |
