> New Work Bench, Top Suggestions?
jfort
post Dec 20 2012, 11:47 AM
I am going to make a new work bench this winter. Maybe 30" by 16'. 4 by 4's. drawers and a shelf across the bottom. A vise. I am just your typical once-in-while car project and home project type guy.
Don't know what to do for the top. I see places make butcher block. I put formica-type stuff on top of 3/4" plywood one time. I've though about a sheet of metal, but something tells me not to do that.
Suggestions? Any other suggestion about a work bench would be appreciated, too. For example, I've thought about getting 2 or 3 half-sized metal shop drawer thinks, bolting them together and putting a work bench top on that. What do you think?
struckn
post Dec 21 2012, 10:56 AM
Here's a PORTABLE HEAVY TABLE WORK BENCH 4' X 4' that I made out of 2x4's, 2x6's and white pre cut Laminate Partical boards 2ft x 4ft. The legs on one side only are cut shorter then the legs on the other side so that caster wheels can level and support the table. By lifting the opposite side it can be rolled around to any where you are working at. Also made several 2ft x8ft wall mounted benches using the white Laminated particle boards. They pretty tuff and reflect light plus easy to clean and not that expensive.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-13764-1356108963.1.jpg)
rwilner
post Dec 21 2012, 08:30 PM
No Ghosts in the Machine
QUOTE(struckn @ Dec 21 2012, 11:56 AM) *
Is that an f4u?? Super cool!
Extra points if you built it and it wasn't an arf!
jfort   New Work Bench   Dec 20 2012, 11:47 AM
URY914   If you want a wood top, try a building supply that...   Dec 20 2012, 11:52 AM
Andyrew   If you want a wood top, try a building supply tha...   Jan 9 2013, 10:25 PM
two-strokejohn   I like metal tops on my workbenches, because they ...   Dec 20 2012, 11:57 AM
jfort   what gauge stainless? how did you hold it down?   Dec 20 2012, 12:04 PM
mwyatt   I used a sheet of stainless over MDF. Don't r...   Dec 20 2012, 12:33 PM
two-strokejohn   what gauge stainless? how did you hold it down? ...   Dec 20 2012, 03:07 PM
kg6dxn   I have a galvanized steel skin on one of mine. I f...   Dec 20 2012, 12:40 PM
DBCooper   It depends a lot on what you want to use it for. ...   Dec 20 2012, 12:44 PM
URY914   Gint's solid core door suggestion is a good...   Dec 20 2012, 01:24 PM
DBCooper   Gint's solid core door suggestion is a goo...   Dec 20 2012, 01:55 PM
Gint   Gint's solid core door suggestion is a good ...   Dec 20 2012, 11:16 PM
underthetire   Check your local C/L first. Sometimes it's rea...   Dec 20 2012, 12:44 PM
abnrdo   I have this one from Sears. 8 Ft Butcher Block B...   Dec 20 2012, 01:10 PM
Vacca Rabite   Plywood. I have made bunches of work benches and t...   Dec 20 2012, 01:12 PM
7TPorsh   You can but stainless steel flashing for roofs in ...   Dec 20 2012, 01:13 PM
URY914   I also have a bench top made from a hollow metal d...   Dec 20 2012, 01:26 PM
stugray   I was going to sugget the hollow metal door also -...   Dec 20 2012, 01:36 PM
7TPorsh   I was going to sugget the hollow metal door also ...   Dec 20 2012, 01:38 PM
dpires914   I was going to sugget the hollow metal door also ...   Dec 20 2012, 07:27 PM
Dasnowman   I was going to sugget the hollow metal door also ...   Dec 21 2012, 01:00 AM
Elliot Cannon   I laminated two 3/4 inch sheets of plywood. Rout...   Dec 20 2012, 01:44 PM
OU8AVW   these look cool http://www.creativeshelters.com/2...   Dec 20 2012, 01:53 PM
Mark Henry   My main bench is 3 heavy industrial steel doors, I...   Dec 20 2012, 03:18 PM
Travis Neff   I did mine with 3/4 plywood and covered in in 20G ...   Dec 20 2012, 03:27 PM
Jon H.   I picked up used 5'x7' x 1/4 plate steel t...   Dec 20 2012, 04:25 PM
yp914   I agree a solid core wood door is the best table t...   Dec 20 2012, 04:38 PM
scotty b   If you want to do a little elbow work, go to a lo...   Dec 20 2012, 04:38 PM
MDG   If you want to do a little elbow work, go to a l...   Dec 20 2012, 07:20 PM
scotty b   If you want to do a little elbow work, go to a ...   Dec 20 2012, 08:00 PM
MDG   [quote name='MDG' post='1787541' date='Dec 20 201...   Dec 21 2012, 12:11 PM
Scott S   I used plywood, and then covered it with the peel ...   Dec 20 2012, 05:19 PM
zonedoubt   Salvaged kitchen laminate countertop. Mine has sto...   Dec 20 2012, 05:48 PM
strawman   Salvaged kitchen laminate countertop. Mine has st...   Dec 20 2012, 06:57 PM
Tom   Here is a pic of my work area. Not as large as I w...   Dec 20 2012, 07:19 PM
URY914   Here is a shot off my vise mounted on my hollow me...   Dec 20 2012, 07:25 PM
URY914   And my grinder mounted my solid core door OAK .......   Dec 20 2012, 07:26 PM
URY914   Drill press is on a peice of plastic laminate coun...   Dec 20 2012, 07:28 PM
URY914   Working as a project manager for a construction co...   Dec 20 2012, 07:30 PM
dpires914   I am going to make a new work bench this winter. ...   Dec 20 2012, 07:43 PM
bigkensteele   http://www.harborfreight.com/60-inch-workbench-934...   Dec 20 2012, 08:07 PM
oldschool   Found this old kitchen table on the side of a road...   Dec 20 2012, 08:55 PM
euro911   This is a freebie I picked up from one of Joe Shar...   Dec 20 2012, 09:04 PM
cwpeden   I covered mine with cheap laminate flooring from h...   Dec 21 2012, 01:17 AM
dian   i did exactly the same. besides i poured this one...   Dec 21 2012, 10:17 AM
rnellums   I love this thread   Dec 21 2012, 10:31 AM
balljoint   I am with scotty on the freebies. I found some gr...   Dec 21 2012, 10:48 AM
DBCooper   I am with scotty on the freebies. I found some g...   Dec 21 2012, 11:22 AM
MDG   Let's see, where are you from again? Good, ...   Dec 21 2012, 12:13 PM
Mark Henry   I am with scotty on the freebies. I found some g...   Dec 21 2012, 05:40 PM
struckn   Here's a PORTABLE HEAVY TABLE WORK BENCH 4...   Dec 21 2012, 10:56 AM
rwilner   Here's a PORTABLE HEAVY TABLE WORK BENCH 4...   Dec 21 2012, 08:30 PM
struckn   [quote name='struckn' post='1787937' date='Dec 21...   Dec 22 2012, 06:28 PM
mhuber45   i went to our local factory 2nd's building sup...   Dec 21 2012, 11:26 AM
Brian_Boss   All I can add to all the good ideas above is to sa...   Dec 21 2012, 05:11 PM
Gint   Eh... mine has crap on it all the time. Might as ...   Dec 21 2012, 05:31 PM
Travis Neff   :)   Dec 22 2012, 11:17 AM
stugray   You mean like this: (its sort of a where's w...   Dec 22 2012, 04:01 PM
Gint   :bump: This thread is much too young to die...   Dec 23 2012, 11:41 AM
Elliot Cannon   You can find great ideas here. http://www.garag...   Dec 23 2012, 12:16 PM
euro911   Yeah. Here you go ... roll away and bench in one m...   Dec 23 2012, 01:29 PM
jfort   finally just got back on line to see if anyone res...   Dec 27 2012, 02:26 PM
rfuerst911sc   Built mine out of 2x6's and over 16 ' long...   Dec 28 2012, 04:58 AM
7TPorsh   how about some shelving and cabinet ideas? I have...   Dec 28 2012, 12:33 PM
euro911   If you're on a budget and just need some inexp...   Dec 28 2012, 09:05 PM
cwpeden   Down the street from my place is a government surp...   Jan 8 2013, 11:08 PM
Michelj13   Here is mine. A little messy, but surprising what ...   Jan 9 2013, 09:48 AM
7TPorsh   I love this thread. Someone should start on on gar...   Jan 9 2013, 10:13 AM
charliew   I picked up a good metal bench with a top shelf fr...   Jan 9 2013, 03:23 PM
montoya 73 2.0   I needed a desk but wanted a workbench so I built ...   Jan 9 2013, 07:29 PM
Gint   This thread... influenced me to clean up my bench ...   Jan 9 2013, 11:16 PM
PanelBilly   Find a local office furniture manufacturer. They...   Jan 10 2013, 12:26 AM
euro911   Long overdue here. Not far behind you, Mike :idea:...   Jan 10 2013, 12:29 AM
stateofidleness   looks like a '78/'79ish Peavey Mace VT Ser...   Jan 10 2013, 12:35 AM
euro911   looks like a '78/'79ish Peavey Mace VT Ser...   Jan 10 2013, 01:08 AM
- Lo-Fi Version Time is now: 13th July 2025 - 10:18 AM
