Temp Sensor |
Temp Sensor |
last337 |
Dec 26 2012, 04:00 PM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
I just got my Haynes and was hoping to have a bit more info in there but this thing is not very good as far as info goes.
I am concerned because at this point I am just unsure if everything having to do with the oil cooler and actual temp of the engine is running correctly (or even there). I can feel a lot of air coming from under the car when the engine is running so I assume the fan is running correctly. However, I am unsure if this is cooling the oil cooler correctly. I am just also a bit unsure whether this temp gauge is working because it never seems to move. Any help is appreciated. I am still a newbie so please be gentle (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) |
SLITS |
Dec 26 2012, 06:40 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
1.) Does the needle jump a bit when you turn the key on? If no, you don't have power.
2.) All the connections for the gauges are under the center console. There are connectors there that tie into the gauge assembly harness. 3.)Green with black trace goes to gauge terminal (oil temp) .... red with white trace goes to + (power) ... Brown to ground .... Blue with black trace are for illumination. Single wire comes from sender on bottom of engine case. |
Lo-Fi Version | Time is now: 17th June 2024 - 10:46 AM |
