| dfelz |
Jul 12 2012, 08:25 PM
beach bum ![]() ![]() Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California
The engine in my 72 1.7L hasn't been driven in 20 years, (IMG:style_emoticons/default/chair.gif) and I want to start prepping the engine to come back to life! I have a general plan to get it running and want to share it, but would really like tips and to-do's while i get this under way since i have never taken on a project like this before.
My plan so far: New gas tank, SS lines, fuel pump, fuel filter (order and on the way) Rebuild kit with new gaskets and such for each carb, will thoroughly clean them out in that process as well New Bosch spark plugs and spark plug wiring set New distributor, (looking at AAs R0231178009) New battery and battery terminals Oil change and new oil filter If anyone thinks that there is some thing must be added to this list prior to me even attempting the first crank please let me know! All suggestions are welcome! Thanks!! (IMG:style_emoticons/default/beerchug.gif) |
| dfelz |
Dec 30 2012, 04:42 AM
A few more small questions!
What does the fuel pump positive wire look like and where should I look to locate it? Where does the green wire from the distributor go? Why do the new Bosch Super Spark plugs i ordered not fit in the stock connectors (they were purchased from AA, and the exact same ones were listed on pelican and other sites to fit my car (IMG:style_emoticons/default/bs.gif) )? I believe they are the WC77... I'll have to check though. Is there any way to get the spark plugs out without removing the covering/cooling tins? Thats all i can think of right now, I'm tired!! (IMG:style_emoticons/default/bye1.gif) |
dfelz 20 year hibernation Jul 12 2012, 08:25 PM
mrbubblehead
The engine in my 72 1.7L hasn't been driven i... Jul 12 2012, 08:42 PM
kg6dxn Change all the rubber fuel hoses. Use correct FI h... Jul 12 2012, 08:42 PM
mrbubblehead also.... if your running carbs and thinking about ... Jul 12 2012, 08:46 PM
Rusty A squirt of oil in each of the cylinders before yo... Jul 13 2012, 09:40 AM
dfelz
A squirt of oil in each of the cylinders before y... Jul 18 2012, 07:33 PM
Rusty
A squirt of oil in each of the cylinders before ... Jul 18 2012, 07:39 PM
skaufmann
A squirt of oil in each of the cylinders before y... Jul 20 2012, 02:20 PM
ottox914 If you have the trans in neutral, and grab the fan... Jul 20 2012, 01:49 PM
dfelz
Does the current fuel pump work? Has it been tes... Aug 1 2012, 12:11 AM
Rusty
Exactly. the only thing that could be worse is ... Jul 20 2012, 02:00 PM
dfelz Alright! Well it has been some time since I ha... Dec 30 2012, 04:38 AM
What does the fu... Dec 30 2012, 08:19 AM
brenz Fuel pump positive wire is black with a red band o... Dec 30 2012, 09:46 AM
oldschool Hey I have a 1.7 sitting in my garage I may be abl... Dec 30 2012, 02:05 PM
dfelz
Fuel pump positive wire is black with a red band ... Dec 30 2012, 03:57 PM
oldschool
Fuel pump positive wire is black with a red band... Dec 30 2012, 04:44 PM
dfelz
ha ha so does the 914kid he has a yellow 914 wit... Dec 30 2012, 09:56 PM
oldschool
ha ha so does the 914kid he has a yellow 914 wi... Dec 30 2012, 10:21 PM
Series9 :D Dec 30 2012, 04:05 PM
dfelz Alright, So I have a problem but need your help fi... Jan 12 2013, 10:32 AM
phatnine11
Alright, So I have a problem but need your help f... Jan 12 2013, 11:18 AM
dfelz
[quote name='dfelz' post='1801161' date='Jan 12 2... Jan 13 2013, 11:54 PM
Rusty How do your grounds look? Especially where your n... Jan 12 2013, 10:53 AM
dfelz
How do your grounds look? Especially where your ... Jan 12 2013, 11:00 AM
Rusty I don't have a picture handy. The factory gro... Jan 12 2013, 11:06 AM
Rusty Found a pic, posted by Jeffs9146 last year.
http:... Jan 12 2013, 11:10 AM
stugray Please tell us that you are not trying to run carb... Jan 13 2013, 03:17 PM
dfelz
Please tell us that you are not trying to run car... Jan 13 2013, 11:48 PM
Gint When the clutch was in the revs climbed really hig... Jan 14 2013, 07:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th September 2026 - 02:14 AM |
