My 3.3L Subie Conversion Thread, Got me some 914rubber stuff |
Chris H. |
Dec 27 2012, 11:02 AM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Finally starting the thread. First, I never would have done this if it weren't for several of you helping me out, especially Ian at:
Cold Water Conversions Ian tolerated dozens of questions from me as I decided which way to go. Thanks again! Here is the candidate (or victim, depending on what side of the fence you are on): A 1975 1.8L with California Emissions...I've had it for almost 11 years. During that time I have logged about 2800 miles on it. I decided to swap it out for a modern drive train so my daughter could drive it so I started looking for a 2.2L Subie and a 2WD auto trans. This setup CAN be made to work with a custom hanger, but it's not a very exciting trans. Think early '90's Camry or Corolla acceleration. I'm sure it could be re-geared but an Audi trans would probably be a much better option. Then I found and SVX for cheap and changed directions entirely. Looks like my kid will be learning to drive a 5 speed Subie! So far I have: Strong running SVX engine 2006 WRX trans purchased from NASIOC If you don't feel like chasing this stuff down Ian will source it for you. Next up I'll post the highlights of the SVX strip-down and note some of the pitfalls, valuable parts, and stuff to be careful not to break! Any feedback, comments, questions, concerns are welcome. I want to do it right. |
Chris H. |
Jan 2 2013, 06:55 PM
Finally wrestled the engine and trans out...
First I cut the front section out where the radiator was so I could (hopefully) slide it out the front. Pre-cut look Top bar cut Bottom bar cut There are 6 17mm bolts on either side of the front suspension. It's fairly obvious that they are the front sub section. Then undo the struts, jack the car way up and the engine, trans, etc will allow you to wrestle it out and forward. The engine naturally leans forward a bit due to the weight but it IS NOT resting on the accessories/drive belt. The oil pan is a roundish shape. As the saying goes...the sawzall always wins. Godspeed Mr SVX... By the way make sure to duct tape any sawzall cuts or you will very likely cut yourself badly or at least tear your clothing. Still have to take out the gas tank and rear diff, but that's not too bad. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:47 AM |
