| alcantera |
Jan 3 2013, 07:43 PM
Newbie ![]() Group: Members Posts: 7 Joined: 19-December 12 From: Heidelberg ontario Member No.: 15,268 Region Association: None |
My conversion ran into a little snag today. I could not install my rebuilt calipers with the backing plates installed . When i removed the backing plates the calipers would bolt on ,but when i tightened the bolts the caliper rubs the rotor . im wondering if the wrong calipers came back from the rebuilder, do i need to shim out the rotor??? . Strange I thought this would be a ten minute job .
| alcantera |
Jan 3 2013, 10:10 PM
i think my problem is I have early hubs not sc hubs ,the caps and hubs are differant
alcantera brake issue Jan 3 2013, 07:43 PM
jimkelly are you talking about the dust shields??
if so, y... Jan 3 2013, 07:45 PM
John What combination of parts do you have there?
On 9... Jan 3 2013, 08:16 PM
wndsnd I put my front shields on backwards.And had same r... Jan 3 2013, 08:58 PM
alcantera Thanks for the prompt reply.,I can clearly see a d... Jan 3 2013, 09:12 PM
Jeff Hail You didnt by chance replace bearings and seals did... Jan 3 2013, 09:18 PM
Eric_Shea 7mm spacers between the caliper1/2s = 20mm rotor. ... Jan 3 2013, 10:18 PM
Eric_Shea Hubs "shouldn't" be a big deal. Tho... Jan 3 2013, 10:21 PM
alcantera
Hubs "shouldn't" be a big deal. Th... Jan 6 2013, 09:28 AM
alcantera Everything fits perfectly, Thanks again guys Jan 6 2013, 09:33 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th November 2026 - 02:04 AM |
