| alcantera |
Jan 3 2013, 07:43 PM
Newbie ![]() Group: Members Posts: 7 Joined: 19-December 12 From: Heidelberg ontario Member No.: 15,268 Region Association: None |
My conversion ran into a little snag today. I could not install my rebuilt calipers with the backing plates installed . When i removed the backing plates the calipers would bolt on ,but when i tightened the bolts the caliper rubs the rotor . im wondering if the wrong calipers came back from the rebuilder, do i need to shim out the rotor??? . Strange I thought this would be a ten minute job .
| Eric_Shea |
Jan 3 2013, 10:18 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
7mm spacers between the caliper1/2s = 20mm rotor. 11mm spacers = 24mm thick rotor. Looks like you have 20mm rotors.
That said, I think John and Jeff are on to something. The shields go on either side. Make sure you have them on properly. And, many struts have those seal seats that Jeff circled removed so make sure yours are there. |
alcantera brake issue Jan 3 2013, 07:43 PM
jimkelly are you talking about the dust shields??
if so, y... Jan 3 2013, 07:45 PM
John What combination of parts do you have there?
On 9... Jan 3 2013, 08:16 PM
wndsnd I put my front shields on backwards.And had same r... Jan 3 2013, 08:58 PM
alcantera Thanks for the prompt reply.,I can clearly see a d... Jan 3 2013, 09:12 PM
Jeff Hail You didnt by chance replace bearings and seals did... Jan 3 2013, 09:18 PM
alcantera i think my problem is I have early hubs not sc hu... Jan 3 2013, 10:10 PM
Eric_Shea Hubs "shouldn't" be a big deal. Tho... Jan 3 2013, 10:21 PM
alcantera
Hubs "shouldn't" be a big deal. Th... Jan 6 2013, 09:28 AM
alcantera Everything fits perfectly, Thanks again guys Jan 6 2013, 09:33 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th November 2026 - 02:04 AM |
