| ThePaintedMan |
Jan 4 2013, 03:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
Hi guys,
I installed new lights and a Jwest fuse kit and now my highs are stuck on. The lights worked fine switching high to low prior to the fuse box swap, but I believe it is wired correctly. To start troubleshooting though, I want to swap out relays first before going back into tearing it all apart. Does anyone know of a relay that is available at most auto parts stores/FLAPS that won't break the bank. I know they are available from Pelican, but being in Florida, I'd rather get one locally tonight if possible. I know I can try to find a SAAB one from the junkyard tomorrow, but curious if there is something I can get at a store first. Would one from a later Beetle work? I think NAPA has those. Thanks! -George |
Cap'n Krusty Your car probably came with the 4 pin relay, and t... Jan 4 2013, 04:39 PM
ThePaintedMan
Your car probably came with the 4 pin relay, and ... Jan 4 2013, 04:53 PM
914Sixer Can you hear the headlight/turn signal switch CLIC... Jan 4 2013, 10:22 PM
kg6dxn You can also use one of these... $5 on ebay. ... Jan 5 2013, 12:14 AM
ThePaintedMan Doh! I should have elaborated I guess. Yes, I ... Jan 5 2013, 12:43 AM
kg6dxn The stock relay is electro/mechanical. A cam insid... Jan 5 2013, 12:47 AM
rhodyguy what's the # on the relay george?
k Jan 5 2013, 09:24 AM
kg6dxn Found this on a web search. From the Samba
http://... Jan 5 2013, 10:16 AM
ThePaintedMan Hey Kevin,
Its the the standard Bosch 111-941-58... Jan 5 2013, 04:39 PM
rhodyguy no M84, just an A. 4 pins. what is the application... Jan 5 2013, 05:20 PM
ThePaintedMan
no M84, just an A. 4 pins. what is the applicatio... Jan 5 2013, 06:03 PM
Cap'n Krusty
no M84, just an A. 4 pins. what is the applicati... Jan 5 2013, 06:28 PM
sixnotfour here is some understanding
http://www.bcae1.com/im... Jan 5 2013, 06:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 03:15 AM |
