| ThePaintedMan |
Jan 4 2013, 03:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
Hi guys,
I installed new lights and a Jwest fuse kit and now my highs are stuck on. The lights worked fine switching high to low prior to the fuse box swap, but I believe it is wired correctly. To start troubleshooting though, I want to swap out relays first before going back into tearing it all apart. Does anyone know of a relay that is available at most auto parts stores/FLAPS that won't break the bank. I know they are available from Pelican, but being in Florida, I'd rather get one locally tonight if possible. I know I can try to find a SAAB one from the junkyard tomorrow, but curious if there is something I can get at a store first. Would one from a later Beetle work? I think NAPA has those. Thanks! -George |
| 914Sixer |
Jan 4 2013, 10:22 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,428 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Can you hear the headlight/turn signal switch CLICK when you pull back on the arm? Do you see any voltage drop when you attempt to go from high to low?
ThePaintedMan Headlight relay alternative at local FLAPS Jan 4 2013, 03:10 PM
Cap'n Krusty Your car probably came with the 4 pin relay, and t... Jan 4 2013, 04:39 PM
ThePaintedMan
Your car probably came with the 4 pin relay, and ... Jan 4 2013, 04:53 PM
kg6dxn You can also use one of these... $5 on ebay. ... Jan 5 2013, 12:14 AM
ThePaintedMan Doh! I should have elaborated I guess. Yes, I ... Jan 5 2013, 12:43 AM
kg6dxn The stock relay is electro/mechanical. A cam insid... Jan 5 2013, 12:47 AM
rhodyguy what's the # on the relay george?
k Jan 5 2013, 09:24 AM
kg6dxn Found this on a web search. From the Samba
http://... Jan 5 2013, 10:16 AM
ThePaintedMan Hey Kevin,
Its the the standard Bosch 111-941-58... Jan 5 2013, 04:39 PM
rhodyguy no M84, just an A. 4 pins. what is the application... Jan 5 2013, 05:20 PM
ThePaintedMan
no M84, just an A. 4 pins. what is the applicatio... Jan 5 2013, 06:03 PM
Cap'n Krusty
no M84, just an A. 4 pins. what is the applicati... Jan 5 2013, 06:28 PM
sixnotfour here is some understanding
http://www.bcae1.com/im... Jan 5 2013, 06:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 03:15 AM |
