> Styrofoam in the Door?, What's supposed to be in there?
able2222
post Jan 7 2013, 07:44 AM
Doing some window track maintenance on a '70 and pulled the door panels off. Found some large styrofoam blocks in the bottom of the door. Questions: 1. did the factory do this? 2. is it a redneck attempt at sound deading by the PO? or 3. is it an after market floatation assist kit (if it is I'm missing the snorkle)?
Nine_14
post Jan 7 2013, 10:09 AM
Region Association: Germany
Don't forget there must be a plastic foil behind the door panel.
Tom_T
post Jan 7 2013, 11:27 AM
TMI....
QUOTE(Nine_14 @ Jan 7 2013, 08:09 AM) *
Although here we'd call it a plastic sheet vapor barrier behind the inner door panel & over the inner frame.
That styrofoam was a DAPO add-on, cuz that will only hold moisture to aid tin worm!
Porsche/VW did inject foam in other body cavities in an ill advised attempt to both sound deaden & waterproof the bodies, which instead turned out to cause water-poof! (IMG:style_emoticons/default/blink.gif)
- Lo-Fi Version Time is now: 26th May 2026 - 02:53 AM
