| PDXMike |
Jan 7 2013, 02:53 PM
Slowly Learning ![]() ![]() Group: Members Posts: 112 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest |
Can anyone confirm if this is the correct drawing for resurfacing the flywheel? Is the 11mm wear limit correct? I ask because the cross-section near the center of the hub doesn't look QUITE the same as my flywheel
| rjames |
Jan 8 2013, 12:22 AM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,447 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
I tried long and hard to find this info but never did. I ended up biting the bullet and buying a new flywheel to play it safe. A new/uncut is something =< than 9mm as that's the measure mine was when purchased new. Nice to know that the new one will most likely outlast the life of the car.
If you re-use yours, make sure that the top of the bolts don't sit above the surface. You don't want them making contact with the clutch disk. I think that's the main concern since you could adjust the clutch for a change of 1mm. Some have shaved the bolt heads down, but I didn't want to go that route. |
PDXMike Flywheel wear limit drawing? Jan 7 2013, 02:53 PM
Dave_Darling Which flywheel are you talking about? 914-4? 914... Jan 7 2013, 04:43 PM
Bartlett 914 I have a flywheel that is in very good condition a... Jan 7 2013, 05:02 PM
Mark Henry Did you get that diagram from one of my old posts?... Jan 8 2013, 08:32 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:54 PM |
