Rear floor pan triangles |
last337 |
Jan 11 2013, 07:36 AM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
I started pulling and poking more and more to get a better assessment of the hell-hole. It appears to be mainly straight down through the fender and through the rear floor pan triangle. My only concern is the condition of the material left on the rear of the long. For the most part the long looks solid enough but has some rust. My friend who will be doing the welding said he can do whatever I need but I am wondering if anyone has welded flat-bar or something along the longs to add stiffness. That may also give the triangle more material to mount to.
worn |
Jan 11 2013, 02:48 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I started pulling and poking more and more to get a better assessment of the hell-hole. It appears to be mainly straight down through the fender and through the rear floor pan triangle. My only concern is the condition of the material left on the rear of the long. For the most part the long looks solid enough but has some rust. My friend who will be doing the welding said he can do whatever I need but I am wondering if anyone has welded flat-bar or something along the longs to add stiffness. That may also give the triangle more material to mount to. I know the feeling. The way to go is to remove each of the areas that have rusted and replace them. In some parts you can quite easily bend sheet metal to fit. I use 24 pack Coke boxes as patterns. If a panel is really shot, it is a great feeling to know you have drilled out the spot welds and properly plopped in a piece from Restoration Designs and rewelded to make it like new. Go that route and drive the car a few weeks later. If you have a good welder, they should want to do it that way anyhow. Good luck, we're all pullin for you. |
Lo-Fi Version | Time is now: 29th May 2024 - 02:24 AM |
