> Timing question - plugging the vacuum advance hose
john_g
post Jan 11 2013, 04:15 PM
I have only had experience using John Muir's static timing method with VW's, so am not used to the strobe light procedure for the 914. So, I have a number of questions:
1) To get a starting point, using a static timing light or voltmeter, what's the static timing mark to use with a '74 2.0 engine - 5º or 7.5º?
2) Before using the strobe light, some instructions say to remove the vacuum hose from the distributor, others say to remove AND plug it with something. What's correct? And, if I plug it, do I plug the hose end or the connector to the distributor, or both? (IMG:style_emoticons/default/confused24.gif)
Thanks.
john_g
post Jan 11 2013, 04:58 PM
Thanks. So ... I only plug the hose end, not the connection to the distributor, right?
rmital
post Jan 11 2013, 05:13 PM
Northeast optimist
QUOTE(john_g @ Jan 11 2013, 05:58 PM) *
Correct, and I like to use a golf tee to plug the hose
- Lo-Fi Version Time is now: 15th March 2026 - 06:25 PM
