| john_g |
Jan 11 2013, 04:15 PM
Member ![]() ![]() Group: Members Posts: 110 Joined: 1-November 12 From: british columbia Member No.: 15,100 Region Association: Canada |
I have only had experience using John Muir's static timing method with VW's, so am not used to the strobe light procedure for the 914. So, I have a number of questions:
1) To get a starting point, using a static timing light or voltmeter, what's the static timing mark to use with a '74 2.0 engine - 5º or 7.5º? 2) Before using the strobe light, some instructions say to remove the vacuum hose from the distributor, others say to remove AND plug it with something. What's correct? And, if I plug it, do I plug the hose end or the connector to the distributor, or both? (IMG:style_emoticons/default/confused24.gif) Thanks. |
| Dave_Darling |
Jan 11 2013, 07:52 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,328 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Just use TDC as a static timing point; it should get you close enough for the engine to run.
With the D-jet system, you don't actually have to plug the vacuum line. It's good practice, though, since leaving it unplugged can cause problems with L-jet or carbs. It also keeps un-filtered air from getting into the engine, which can be nice if you live in a dusty area. --DD |
john_g Timing question - plugging the vacuum advance hose Jan 11 2013, 04:15 PM
SLITS 2.0L engine .... 27 degrees @ 3000 RPM** is what I... Jan 11 2013, 04:39 PM
john_g Thanks. So ... I only plug the hose end, not the ... Jan 11 2013, 04:58 PM
rmital
Thanks. So ... I only plug the hose end, not the... Jan 11 2013, 05:13 PM
SLITS
Thanks. So ... I only plug the hose end, not th... Jan 11 2013, 05:40 PM
john_g
Just use TDC as a static timing point; it should ... Jan 13 2013, 04:37 PM
last337 Where is the vacuum connection you guys are talkin... Jan 13 2013, 05:11 PM
Dave_Darling We're talking specifically about D-jetronic fu... Jan 13 2013, 05:44 PM
last337
We're talking specifically about D-jetronic f... Jan 13 2013, 07:04 PM
Dave_Darling The #2 plug? That doesn't sound familiar. Is... Jan 13 2013, 09:37 PM
last337
The #2 plug? That doesn't sound familiar. I... Jan 14 2013, 09:47 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 07:53 PM |
