> 20 year hibernation, she lives to tell another tale! (1/13/13)
dfelz
post Jul 12 2012, 08:25 PM
beach bum
The engine in my 72 1.7L hasn't been driven in 20 years, (IMG:style_emoticons/default/chair.gif) and I want to start prepping the engine to come back to life! I have a general plan to get it running and want to share it, but would really like tips and to-do's while i get this under way since i have never taken on a project like this before.
My plan so far:
New gas tank, SS lines, fuel pump, fuel filter (order and on the way)
Rebuild kit with new gaskets and such for each carb, will thoroughly clean them out in that process as well
New Bosch spark plugs and spark plug wiring set
New distributor, (looking at AAs R0231178009)
New battery and battery terminals
Oil change and new oil filter
If anyone thinks that there is some thing must be added to this list prior to me even attempting the first crank please let me know! All suggestions are welcome!
Thanks!! (IMG:style_emoticons/default/beerchug.gif)
Rusty
post Jan 12 2013, 11:06 AM
I don't have a picture handy. The factory ground strap was a braided strap that went from a nut on the rear transmission cover to a stud on the body.
If you get under the car and start looking there, you should see it. You probably had to disconnect it to drop the engine/transmission combo. If you didn't disconnect it, it likely broke under the weight of dropping the engine/xmsn.
When you check both the battery ground cable and the xmsn ground strap, make sure both ends are clean and the surfaces they are connected to are clean and shiny. Some electrical grease would be good preventative maintenance.
dfelz   20 year hibernation   Jul 12 2012, 08:25 PM
mrbubblehead   The engine in my 72 1.7L hasn't been driven i...   Jul 12 2012, 08:42 PM
kg6dxn   Change all the rubber fuel hoses. Use correct FI h...   Jul 12 2012, 08:42 PM
mrbubblehead   also.... if your running carbs and thinking about ...   Jul 12 2012, 08:46 PM
Rusty   A squirt of oil in each of the cylinders before yo...   Jul 13 2012, 09:40 AM
dfelz   A squirt of oil in each of the cylinders before y...   Jul 18 2012, 07:33 PM
Rusty   A squirt of oil in each of the cylinders before ...   Jul 18 2012, 07:39 PM
skaufmann   A squirt of oil in each of the cylinders before y...   Jul 20 2012, 02:20 PM
ottox914   If you have the trans in neutral, and grab the fan...   Jul 20 2012, 01:49 PM
dfelz   Does the current fuel pump work? Has it been tes...   Aug 1 2012, 12:11 AM
Rusty   Exactly. the only thing that could be worse is ...   Jul 20 2012, 02:00 PM
dfelz   Alright! Well it has been some time since I ha...   Dec 30 2012, 04:38 AM
dfelz   A few more small questions! What does the fue...   Dec 30 2012, 04:42 AM
mepstein   A few more small questions! What does the fu...   Dec 30 2012, 08:19 AM
brenz   Fuel pump positive wire is black with a red band o...   Dec 30 2012, 09:46 AM
oldschool   Hey I have a 1.7 sitting in my garage I may be abl...   Dec 30 2012, 02:05 PM
dfelz   Fuel pump positive wire is black with a red band ...   Dec 30 2012, 03:57 PM
oldschool   Fuel pump positive wire is black with a red band...   Dec 30 2012, 04:44 PM
dfelz   ha ha so does the 914kid he has a yellow 914 wit...   Dec 30 2012, 09:56 PM
oldschool   ha ha so does the 914kid he has a yellow 914 wi...   Dec 30 2012, 10:21 PM
Series9   :D   Dec 30 2012, 04:05 PM
dfelz   Alright, So I have a problem but need your help fi...   Jan 12 2013, 10:32 AM
phatnine11   Alright, So I have a problem but need your help f...   Jan 12 2013, 11:18 AM
dfelz   [quote name='dfelz' post='1801161' date='Jan 12 2...   Jan 13 2013, 11:54 PM
Rusty   How do your grounds look? Especially where your n...   Jan 12 2013, 10:53 AM
dfelz   How do your grounds look? Especially where your ...   Jan 12 2013, 11:00 AM
Rusty   I don't have a picture handy. The factory gro...   Jan 12 2013, 11:06 AM
Rusty   Found a pic, posted by Jeffs9146 last year. http:...   Jan 12 2013, 11:10 AM
stugray   Please tell us that you are not trying to run carb...   Jan 13 2013, 03:17 PM
dfelz   Please tell us that you are not trying to run car...   Jan 13 2013, 11:48 PM
Gint   When the clutch was in the revs climbed really hig...   Jan 14 2013, 07:38 AM
- Lo-Fi Version Time is now: 10th September 2026 - 02:14 AM
