last337 |
Member ![]() ![]() Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None ![]() |
Ugh I was all set to set timing and valve clearance today. I pushed car out of shop to clean up before starting. It came time to mo be back into shop and upon turning key I heard a pop and then nothing. Checked all under dash fuses and everything looks good. Pulled connections to relay box in engine compartment and everything looks good. If I turn on hazards I hear them clicking but see no lights. If I turn key on the hazards stop clicking. Where should I start?
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Replace the electrical portion of the ignition switch and see if that cures the problems.
They will crack from the heat generated by power thru them and cause all sorts of problems. |
Lo-Fi Version | Time is now: 1st August 2025 - 03:02 AM |
