> Timing question - plugging the vacuum advance hose
john_g
post Jan 11 2013, 04:15 PM
I have only had experience using John Muir's static timing method with VW's, so am not used to the strobe light procedure for the 914. So, I have a number of questions:
1) To get a starting point, using a static timing light or voltmeter, what's the static timing mark to use with a '74 2.0 engine - 5º or 7.5º?
2) Before using the strobe light, some instructions say to remove the vacuum hose from the distributor, others say to remove AND plug it with something. What's correct? And, if I plug it, do I plug the hose end or the connector to the distributor, or both? (IMG:style_emoticons/default/confused24.gif)
Thanks.
Dave_Darling
post Jan 13 2013, 09:37 PM
914 Idiot
The #2 plug? That doesn't sound familiar. Is it on the carb manifold, or coming out of the head, or something else? If it's coming out of the head, then it's for the Positive Crankcase Ventilation system.
--DD
- Lo-Fi Version Time is now: 15th March 2026 - 06:32 PM
