| shuie |
Jan 14 2013, 09:31 AM
Member ![]() ![]() Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
I want to install a later style 911 sway bar on my '71 914. I am not going to 5 lug and I do not want to get into changing the struts on my '71 or swapping an entire 911 front suspension onto the car. I just want to use the later 911 under the body sway bar with the early 914 struts & non vented brakes.
I know I need the tabs for the A-arms. Can I use the 911 A-arms and keep my early struts? Will the early 914 balljoints work in the 911 A-arms? Do I need the aluminum cross member from the 911? TIA |
| Dave_Darling |
Jan 14 2013, 09:50 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,342 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The tabs on the A arms for the under-body bar are quite different from those for the through-body bar. Or at least in a different location. So you'll either need to fab and weld on the 911-style tabs, or use 911 A arms. I believe you'll need to switch to 911 torsion bars if you go with 911 A arms--obviously with the 911 height adjuster as well.
I don't think you need the 911 crossmember, I think (not sure!) that the brackets for the under-body bar bolt up to the mounting holes for the crossmember, not to the crossmember itself. Why are you changing over? The under-body style has worse geometry, is kind of a pain to install and remove, cannot be made adjustable, and requires a bunch of extra work as you can see. --DD |
shuie conversion to 911 underbody front sway bar Jan 14 2013, 09:31 AM
shuie
Im just looking ... Jan 14 2013, 10:24 AM
ruby914
Im just looking... Jan 14 2013, 10:48 AM
jimkelly dave - as usual - you make some good points here -... Jan 14 2013, 06:24 PM
jcd914 The brackets/bushing mounts for the under body bar... Jan 14 2013, 10:55 AM
carr914 I have the Whole Set-up (A Arms, Alum Crossmember,... Jan 14 2013, 06:45 PM
Jgilliam914 My72 had a under body sway bar when I purchased it... Jan 14 2013, 07:03 PM
falconfp2001
I want to install a later style 911 sway bar on m... Jan 14 2013, 10:58 PM
brant
I want to install a later style 911 sway bar on ... Jan 15 2013, 12:13 AM
falconfp2001
[quote name='falconfp2001' post='1802610' date='J... Jan 16 2013, 12:44 AM
SLITS In all the cars I've played with, I have never... Jan 16 2013, 08:16 AM
MDG
I've built a couple of cars with the under b... Jan 16 2013, 08:30 AM
Racer Chris
The only drawback is that the rack/master cylind... Jan 16 2013, 08:53 AM
Spoke I did the 911 A-arms, t-bars, aluminum crossmember... Jan 16 2013, 09:36 AM
Eric_Shea I'd find a way to fix that through body set up... Jan 16 2013, 11:03 PM
Eric_Shea
:agree: 200% Jan 16 2013, 11:04 PM
dfelz Soooo, I just noticed that one of the random items... Feb 9 2013, 03:53 AM
Spoke
My questions is, can i still use my stock 914 a-a... Feb 9 2013, 06:26 AM
scotty b Just run both, then everyone will think you know s... Feb 9 2013, 07:39 AM
Racer Chris
Just run both, then everyone will think you know ... Feb 9 2013, 08:36 AM
tscrihfield
[quote name='scotty b' post='1817426' date='Feb 9... Feb 9 2013, 08:49 AM
dfelz
Just run both, then everyone will think you know ... Feb 9 2013, 01:37 PM
larryM i did this about 15 yrs ago
- same reason - oem... Feb 9 2013, 11:11 PM
scotty b
- same reason - oe... Feb 10 2013, 10:26 AM
dfelz thanks Larry. I contacted bruce earlier today abou... Feb 10 2013, 01:14 AM
Eric_Shea :agree: I'd love to see details on the origina... Feb 10 2013, 10:32 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th June 2026 - 05:52 PM |
