| shuie |
Jan 14 2013, 09:31 AM
Member ![]() ![]() Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
I want to install a later style 911 sway bar on my '71 914. I am not going to 5 lug and I do not want to get into changing the struts on my '71 or swapping an entire 911 front suspension onto the car. I just want to use the later 911 under the body sway bar with the early 914 struts & non vented brakes.
I know I need the tabs for the A-arms. Can I use the 911 A-arms and keep my early struts? Will the early 914 balljoints work in the 911 A-arms? Do I need the aluminum cross member from the 911? TIA |
| jcd914 |
Jan 14 2013, 10:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,097 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The brackets/bushing mounts for the under body bar attach to the support brackets going from the cross bean back to the body. You will have to drill and thread or add a nut so the bushing brackets can bolt on. These supports for the aluminum cross bar are separate pieces ad are a bit thicker and wider and predrilled and threaded.
The easy way would be to get a complete 911 set up minus the struts, you get the bar, brackets bushings, A-arms with mounts, T-bars, cross beam, under bell pan, etc. Your ball joints will fit the 911 A-arms directly, so no need to change your struts. That said I would find a stock 914 or early 911 thru body sway bar and pull the tank and install the aftermarket nut plats for a thru body bar and go that route. It is better set up, under body bars have bad geometry, no adjustment, they are made for a much heavier car, are difficult to detach/attach to the A-arm Used stock bar set ups come up around $200 bucks and Use aftermarket adjustables are not much more. There is plenty of room to relocate the fuel pump later if you want, although most relocate the pump down by the steering rack & cross beam not under the tank (easier to get to). Jim |
shuie conversion to 911 underbody front sway bar Jan 14 2013, 09:31 AM
Dave_Darling The tabs on the A arms for the under-body bar are ... Jan 14 2013, 09:50 AM
shuie
Why are you changing over?
Im just looking ... Jan 14 2013, 10:24 AM
ruby914
Im just looking... Jan 14 2013, 10:48 AM
jimkelly dave - as usual - you make some good points here -... Jan 14 2013, 06:24 PM
carr914 I have the Whole Set-up (A Arms, Alum Crossmember,... Jan 14 2013, 06:45 PM
Jgilliam914 My72 had a under body sway bar when I purchased it... Jan 14 2013, 07:03 PM
falconfp2001
I want to install a later style 911 sway bar on m... Jan 14 2013, 10:58 PM
brant
I want to install a later style 911 sway bar on ... Jan 15 2013, 12:13 AM
falconfp2001
[quote name='falconfp2001' post='1802610' date='J... Jan 16 2013, 12:44 AM
SLITS In all the cars I've played with, I have never... Jan 16 2013, 08:16 AM
MDG
I've built a couple of cars with the under b... Jan 16 2013, 08:30 AM
Racer Chris
The only drawback is that the rack/master cylind... Jan 16 2013, 08:53 AM
Spoke I did the 911 A-arms, t-bars, aluminum crossmember... Jan 16 2013, 09:36 AM
Eric_Shea I'd find a way to fix that through body set up... Jan 16 2013, 11:03 PM
Eric_Shea
:agree: 200% Jan 16 2013, 11:04 PM
dfelz Soooo, I just noticed that one of the random items... Feb 9 2013, 03:53 AM
Spoke
My questions is, can i still use my stock 914 a-a... Feb 9 2013, 06:26 AM
scotty b Just run both, then everyone will think you know s... Feb 9 2013, 07:39 AM
Racer Chris
Just run both, then everyone will think you know ... Feb 9 2013, 08:36 AM
tscrihfield
[quote name='scotty b' post='1817426' date='Feb 9... Feb 9 2013, 08:49 AM
dfelz
Just run both, then everyone will think you know ... Feb 9 2013, 01:37 PM
larryM i did this about 15 yrs ago
- same reason - oem... Feb 9 2013, 11:11 PM
scotty b
- same reason - oe... Feb 10 2013, 10:26 AM
dfelz thanks Larry. I contacted bruce earlier today abou... Feb 10 2013, 01:14 AM
Eric_Shea :agree: I'd love to see details on the origina... Feb 10 2013, 10:32 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th June 2026 - 04:54 PM |
