| shuie |
Jan 14 2013, 09:31 AM
Member ![]() ![]() Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
I want to install a later style 911 sway bar on my '71 914. I am not going to 5 lug and I do not want to get into changing the struts on my '71 or swapping an entire 911 front suspension onto the car. I just want to use the later 911 under the body sway bar with the early 914 struts & non vented brakes.
I know I need the tabs for the A-arms. Can I use the 911 A-arms and keep my early struts? Will the early 914 balljoints work in the 911 A-arms? Do I need the aluminum cross member from the 911? TIA |
| falconfp2001 |
Jan 14 2013, 10:58 PM
Pancho Pantera ![]() ![]() Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I want to install a later style 911 sway bar on my '71 914. I am not going to 5 lug and I do not want to get into changing the struts on my '71 or swapping an entire 911 front suspension onto the car. I just want to use the later 911 under the body sway bar with the early 914 struts & non vented brakes. I know I need the tabs for the A-arms. Can I use the 911 A-arms and keep my early struts? Will the early 914 balljoints work in the 911 A-arms? Do I need the aluminum cross member from the 911? TIA This is what I did. I sourced the 911 a-arms, steel cross member and the under body sway bar as a complete unit purchased online. Don't remember where I got it but you can find a nice one on the Samba but it is a little pricy for me however, it comes with the Struts, hubs and rotors. I spent maybe 250.00 on mine. I had to replace the ball joints during the install. They must match your struts. Took me a half day to install and then take to the shop to get it aligned. People say it won't be that much different but it is a lot flatter in the corners than before and you can feel the thicker torsion bars. When they say not adjustable they actually mean not adjustable without removing the bar and replacing with a thicker one. It isn't that hard to do and I honestly don't know why they think it is difficult. The through body is a lot more work to install and will not benefit you much unless you plan to race. Just my opinion but hey, a lot of people AX these cars. |
shuie conversion to 911 underbody front sway bar Jan 14 2013, 09:31 AM
Dave_Darling The tabs on the A arms for the under-body bar are ... Jan 14 2013, 09:50 AM
shuie
Why are you changing over?
Im just looking ... Jan 14 2013, 10:24 AM
ruby914
Im just looking... Jan 14 2013, 10:48 AM
jimkelly dave - as usual - you make some good points here -... Jan 14 2013, 06:24 PM
jcd914 The brackets/bushing mounts for the under body bar... Jan 14 2013, 10:55 AM
carr914 I have the Whole Set-up (A Arms, Alum Crossmember,... Jan 14 2013, 06:45 PM
Jgilliam914 My72 had a under body sway bar when I purchased it... Jan 14 2013, 07:03 PM
brant
I want to install a later style 911 sway bar on ... Jan 15 2013, 12:13 AM
falconfp2001
[quote name='falconfp2001' post='1802610' date='J... Jan 16 2013, 12:44 AM
SLITS In all the cars I've played with, I have never... Jan 16 2013, 08:16 AM
MDG
I've built a couple of cars with the under b... Jan 16 2013, 08:30 AM
Racer Chris
The only drawback is that the rack/master cylind... Jan 16 2013, 08:53 AM
Spoke I did the 911 A-arms, t-bars, aluminum crossmember... Jan 16 2013, 09:36 AM
Eric_Shea I'd find a way to fix that through body set up... Jan 16 2013, 11:03 PM
Eric_Shea
:agree: 200% Jan 16 2013, 11:04 PM
dfelz Soooo, I just noticed that one of the random items... Feb 9 2013, 03:53 AM
Spoke
My questions is, can i still use my stock 914 a-a... Feb 9 2013, 06:26 AM
scotty b Just run both, then everyone will think you know s... Feb 9 2013, 07:39 AM
Racer Chris
Just run both, then everyone will think you know ... Feb 9 2013, 08:36 AM
tscrihfield
[quote name='scotty b' post='1817426' date='Feb 9... Feb 9 2013, 08:49 AM
dfelz
Just run both, then everyone will think you know ... Feb 9 2013, 01:37 PM
larryM i did this about 15 yrs ago
- same reason - oem... Feb 9 2013, 11:11 PM
scotty b
- same reason - oe... Feb 10 2013, 10:26 AM
dfelz thanks Larry. I contacted bruce earlier today abou... Feb 10 2013, 01:14 AM
Eric_Shea :agree: I'd love to see details on the origina... Feb 10 2013, 10:32 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th June 2026 - 04:56 PM |
