Refurbish hydraulic lifters with new springs? |
AE354803 |
Jan 16 2013, 05:40 PM
Member Group: Members Posts: 232 Joined: 13-August 12 From: Southern California Member No.: 14,801 Region Association: Southern California |
I have a webcam hydraulic cam and lifters in my 2.0 type IV, I am going to refurbish the lifters and figured I would replace the internals of the lifters while I was in there.
The purpose would be to squeeze more life out of the lifters before I have to crack the case open (at which point in time I will replace the cam and lifters with solid versions). I will replace only the springs and keep the two pieces of the body and the original ball check valve. Does anyone have any advice on this? I am going to clean up the old lifters regardless since I suspect they are not filling correctly due to valvetrain noise, however I'm not sure that replacing the internals would be appropriate? It should avoid the issue with having the lifter surfaces and cam break in together by keeping the original surfaces. I've also considered the possibility of keeping only the part of the original lifter that mates with the cam and replacing the internals and the other part of the body. However I believe due to the mating tolerances in the manufacturing of lifters that this might be a bad move. Thanks for any help. |
messix |
Jan 16 2013, 08:00 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
where have you found a source for the internal parts of the lifters.
AE354803 |
Jan 16 2013, 09:10 PM
phatnine11 |
Jan 16 2013, 09:25 PM
Member Group: Members Posts: 286 Joined: 22-March 05 From: Rancho Cucamonga, CA Member No.: 3,798 |
AE354803 |
Jan 16 2013, 09:39 PM
where have you found a source for the internal parts of the lifters. Just going to use some new lifters for their guts. why not just use the new lifters? I've been told new lifters on a used cam will self destruct in this engine. It seemed to be the consensus at least. I would prefer to do use the new ones though. |
Lo-Fi Version | Time is now: 4th June 2024 - 08:09 PM |
