No left side lights...., what are the obvious places to look? |
billh1963 |
Jan 20 2013, 01:28 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Working on the green car today and notice that I don't have any left side running lights (side marker, tailights, etc.). The right side is fine and the headlights work okay. Anything obvious to check?
scotty b |
Jan 20 2013, 07:26 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
is the front signal light working ? If it is then I'm betting it is the same loose bulb issue I ran into. When the side lights were out, everything else still worked. If you have lost the t.s. and tailights on the left side then there is def. another issue
billh1963 |
Jan 20 2013, 07:47 PM
is the front signal light working ? If it is then I'm betting it is the same loose bulb issue I ran into. When the side lights were out, everything else still worked. If you have lost the t.s. and tailights on the left side then there is def. another issue With the parking lights on, the entire left side is dead. Side marker, tail light, turn signal are dark. With the headlights on it's still dark on the left side; however, the headlight itself comes on. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:24 PM |
