RON S. |
9140430841, FINALLY RUNNING ![]() ![]() ![]() Group: Members Posts: 1,216 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States ![]() |
I've got t-signals on my 914/6 that just refuse to blink. (IMG:style_emoticons/default/sad.gif)
Here's the stats,I hope someone may have an answer. 1.)All the lighting on the car is working.IE.brake lights,all parking lights when h-light switch is in that position.Headlights and parking lights when h-switch is in full-on position.There are no burned out or non-working bulbs on the car.There are no disconnected wires. 2.)When I engage the signal lever in either direction,the indicator on the dash comes on.The corresponding front & rear signal bulbs come on also. The result is the same when engaging the left or right indicators. (IMG:style_emoticons/default/mad.gif) 3.)I have changed the signal relay under the dash 3 times,with signal relays from 914s that do have working signals.None would allow the signals to blink. (IMG:style_emoticons/default/headbang.gif) There are no hacked up wires behind the dash,everything appears plugged-up as designed. The car is a Euro-model if that helps. Tell me guys,what am I missing. (IMG:style_emoticons/default/wacko.gif) Ron |
RON S. |
Rich,
Everything has been tried w/the key in the on position. When the 4-way em-flashers are engaged all the bulbs light up.Fronts,rears,&dash ind'rs,but they don't blink. Every other electrical system in the car works.I.E. horn,radio,wipers,heater,interior lights.etc.etc. It has to something so simple that I know I'll feel stupid for not knowing that in the first place. Bad ground maybe? Ron |
Lo-Fi Version | Time is now: 19th July 2025 - 08:35 PM |
