Proud New Owner, I got to enjoy this beautiful girl for a week before I had a starting issue. looking for help with any diagnostic |
wolfeman1727 |
Jan 23 2013, 11:45 PM
Newbie Group: Members Posts: 8 Joined: 4-November 12 From: Stockton, CA Member No.: 15,113 Region Association: Central California |
Hi all,
I am the ecstatic new owner of a slightly neglected 1973 914, 1.7 model which someone has put a 2.0 in. I got the car with first gear problems and ended up having to take apart the tranny and replace the first gear synchro and dogteeth... which I did myself successfully with out terrible difficulty. I got to Drive this sweet little thing around for about a week and the engine sputtered and died on me. It doesn't get gas -replaced the fuel pump -replaced the filter still no avail The leads in the fuel pump plug read a laughable .2 volts when the ignition is on and the engine turned over. Im not getting the power -replaced relay -cleaned all connections on the regulator plate Im getting 12 volts across the leads attached to the relay, but the relay isnt closing my circuit. Any Ideas?? I miss driving the darn thing! (IMG:style_emoticons/default/pray.gif) |
wolfeman1727 |
Jan 24 2013, 06:34 PM
The tank was just filled up when I developed this issue... and it all drained nicely from the hose attached to the pump... no clogs or bad lines.
Im pretty confident my lack of voltage is the issue at this point. Time to double check all my fuses and connections |
Lo-Fi Version | Time is now: 1st June 2024 - 07:59 PM |
